    Junior Member 69MyWay's Avatar
    Central Florida
    black/red/black
    69 Camaro 69&85 Vettes
    Suggest engine mods for my LS1 project (budget)
    I am putting a LS1 in a 1985 Corvette:
    Specs:
    4L60E trans
    3.07 gears
    313 30 rear tires
    REQUIREMENTS:
    1. Mid to low 12 second 1/4 miles
    2. Smooth idle - (wife will be driving it to work for a while)
    3. A/C functional (no running hot problems).
    I currently have a 1998 LS1 stock with an extra set of 2000 center screw LS1 heads and a complete 5.3 for spare parts. My intake is a non-EGR LS1 intake. I will be running shorty headers, no cats.
    BUDGET IS CRUCIAL - Used parts, ZO6 parts...etc, are all good!
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    look for a used 224 cam with a 114 lsa for a good idle. great power and totally streetable
    College Station TX
    2000 &2002 Z28
    no2 done right !
    Cheap and proven to go high 10's on a stock engine when done right
    GMHP had an article of a lt1 running low 11's with less then 4k i think
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    no2 done right !
    He just wants to run 12's, N2O is definitely overkill for that. Personally I would never run Nitrous through my motor, just doesn't seem worth it to me, no matter how much faster you can run while spraying.
    Some good mods for the '98 motor you have:
    LS6 Intake Manifold
    Long Tube Headers (Pacesetters are $289, if they will fit your car)
    Stall Converter
    Shift Kit
    Tune
    Throttle body Bypass Mod (Free)
    Those mods should easily put you in the mid-low 12's
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i may have my slp set up for sale soon, ls6 intake 806 ported heads for an 98, and the cam. this kot was bought from slp by the guy who had the car before me. if interested pm me.i ran 12.59 on the motor with 2,800 stall. thanks.
    Central Florida
    black/red/black
    Are the 806 heads the perimeter screw heads from 97-98?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    Quote Originally Posted by 69MyWay View Post
    yes.
    Ratdaddy07
    Guest
    Lower gear in the rear-end should help and can be done fairly cheap. 3.73 should have you at peak RPM at the line.
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    What are the specs on the cam? how extensive of a port job on those heads? ALso how much? pm me
  1. Check my list of mods and suggest what to do next
    By Hurley711 in forum General Help
    Last Post: 06-20-2010, 06:59 PM
  2. Budget Mods for a 1999 Z28
    By MarcusJ in forum General Help
    Last Post: 12-12-2009, 11:24 PM
  3. Replies: 12
    Last Post: 09-09-2007, 04:23 PM
  4. budget minded performance mods
    By 5150 in forum General Help
    Last Post: 09-10-2005, 01:32 PM
