Results 1 to 11 of 11
Thread: budget minded performance mods
08-24-2005, 02:23 PM #1
hello all im pretty new to the site,as you can tell by my posts. built a few street rods and a 74 blazer with a stroker and some sqeeze, for the sand dunes and mud bogs. my question is being new to the computer controlled world of performance, what are some inexpensive easy mods i can do for my z/28 that i purchased about a month ago? already have magnaflow catback ,k&n filter,and hypertech programer,car was bone stock when i bought it. any tips would be appreciated, thanks.
08-26-2005, 05:02 AM #2member since may 2000
- Dec 2002
- n/w chicago
nothing is really cheap for ls1 cars.
if you can install the items yourself youll save alot of money.
air lid is about $100 and about a 10h.p bump
nitto555r tires are about 300 for a set and really make a difference off the line.
pacesetter headers are about 500 for the coated ones and off road y pipe.
a tci stall converter is 500-600 and you get great gains2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
08-26-2005, 09:53 AM #3
a new or descreened MAF should also help this should give you some Ideas
http://chevyhiperformance.com/techar...148_0207_tech/ it gives some chaper ideas as does some of the other tech articles here
08-26-2005, 10:03 AM #4used and abused at wot
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
stay away from a new MAF, the stocker are good for up to 500hp, and most people have had a bad experience with aftermarket once. Me I got lucky no problems with my slp.
also check into the freebie mods that you can do your self.
Also build from the ground up, meaning suspenion and braking before power, if your lookin to build into big hp later on.
subframe connectors are a must for a first mod,
lid
underdrive pulley
CAI
are a good bolt on start!! for under $300.00
08-26-2005, 11:40 AM #5Jesus died to save you!
- North Olmsted, OH
Navy Blue Metallic- 2000 Camaro Z28
There a couple free mods listed in here also some good guides for some common mods done to F-bodies.
http://www.installuniversity.com/ins...sity/index.htm2000 NBM Camaro Z28
Mods:
SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
08-26-2005, 11:42 AM #6Jesus died to save you!
- North Olmsted, OH
I forgot go to the "Tech Articles" section.
08-26-2005, 11:42 AM #7Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
sfc's, lid, tb, tb bypass, pulley and belts, phb, lca's ......about 100-150 a piece except for the pulley and tb bypass...plugs, wires, so many little things.
08-27-2005, 10:51 AM #8
are these good for an lt1 also or no?
08-27-2005, 11:14 PM #9BlackHawk T/AGuestYep but the parts won't be exactly the same.
Originally Posted by Qwk94Z28
08-28-2005, 05:33 AM #10Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Performance Mods/RWHP
I posted this over in the GTO section...but it is LS1/2 specific...
may help you with your decision....
http://ls1.com/forums/showthread.php?t=966
09-10-2005, 01:32 PM #11Junior Member
- St. Peters, MO
Navy Blue Metallic- 2001 WS6
Cut the bottom of the airbox out, buy a lid, and do an exhaust cutout. These things should easily knock of more than 3 tenths. If you take it to the track go on a 1/4 tank of gas, take out the spare and jack and any other loose things you have in the car, and drop the rear tires to 22 psi at the track and inflate to 40 psi in the front(make sure to set the tires back to normal pressure before you leave the track). All of
these things should get you down to a 13.0 13.1 in good weather in a 2000 model.
1970 Chevrolet Camaro - Performance Minded
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 10-05-2011, 04:20 PM -
Budget Mods for a 1999 Z28
By MarcusJ in forum General HelpReplies: 22Last Post: 12-12-2009, 11:24 PM -
350 dollar budget...need best performance mods for 02 v6 fbird
By larryndog in forum V6Replies: 12Last Post: 09-09-2007, 04:23 PM -
Suggest engine mods for my LS1 project (budget)
By 69MyWay in forum Internal EngineReplies: 8Last Post: 01-27-2007, 10:17 AM
