Results 1 to 13 of 13
01-22-2007, 02:38 PM #1
Secondary Air injection codes popping up
I have 5 codes showing up on my car:
DTC P0410 Secondary Air Injection (AIR) System
DTC P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
DTC P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1
DTC P1415 Secondary Air Injection (AIR) System Bank 1
DTC P1416 Secondary Air Injection (AIR) System Bank 2
Can anyone tell me How I can get this fixed? What it involves?
Thanks for the help.
01-22-2007, 03:15 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Damn, you hit the AIR code jackpot!
Is it still on the car? If it is first thing to check for P0410/P0412/P0418 is the air pump fuse under the hood. P1415/P1416 individually is the air check valves. Don't need it for emissions in Florida so you could do !AIR or just keep it and have the codes turned off. You can look up the codes/diagnostics at gearchatter.com
01-22-2007, 09:24 PM #3
lol yeah I know, question: what is the air check valves and how can i get the codes turned off so they don't keep popping up?
01-22-2007, 10:11 PM #4
01-24-2007, 02:43 PM #5
Thanks a lot, It was the fuse for the first three codes. But the P1415/P1416 still pop up some times. Would that have anything to do with the fact that I did the egr mod?
01-24-2007, 03:06 PM #6Senior Member
- Jul 2005
- Jacksonville, FL
Don't think so, secondary air and EGR are separate. When I had P1416 it was just clogged with carbon deposits, replaced it and went away. GM PN for the air check valves is 12565503, but are available at your local parts store too.
01-26-2007, 03:35 PM #7
yeh i just replaced both AIR valves, $12.25 apeice from Advance.
01-26-2007, 04:19 PM #8Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
I tend to see Secondary AIR codes a lot this time of the year and there's actually nothing wrong.
Secondary AIR is a stupid air injection system that shoots extra air into the exhaust stream to help the catalytic converter deal with the richer mixture an engine has at cold start. When it's really cold &/or humid outside it doesn't work quite as well as the PCM expects it to, thus the code(s).
01-26-2007, 10:26 PM #9
well damn, i guess i wasted 24.50 but now i got no check engine light so it was worth it to me, hhehe, now i gotta go put on some headers and a y pipe, peace all
01-27-2007, 05:14 AM #10Member
- Oct 2006
- Oklahoma City
At $12 ea it was worth it as they do go out from time to time. If the codes stay away then it was time.
If your area has a high incidence of going from hot & humid during the day to below the dew point at night moisture builds up in that system which eventually corrodes things.
01-27-2007, 03:36 PM #11
That might be whats going on with mine.
01-27-2007, 05:59 PM #12
Well, my opinion is that in todays parts world $25 is a cheap fix.
01-27-2007, 06:12 PM #13Senior Member
- Jul 2005
- Jacksonville, FL
Yeah it is, and that's for 2 parts and possibly 2 separate codes.
What is the secondary air injection system
By Street Fighter in forum General HelpReplies: 13Last Post: 03-21-2015, 08:31 AM -
Help: Secondary Air Injection
By FirehawkM6 in forum External EngineReplies: 5Last Post: 10-15-2012, 09:17 AM -
Help: secondary air injection
By mvinson in forum General HelpReplies: 4Last Post: 06-09-2012, 05:53 PM -
Secondary Air Injection System Bank 1
By Naaman in forum General HelpReplies: 14Last Post: 07-09-2011, 07:27 AM -
99 trans am secondary air injection
By MattB75 in forum External EngineReplies: 3Last Post: 01-27-2008, 07:29 PM
