    Member FirehawkM6's Avatar
    Mar 2010
    Nor Cal
    2001 Trans Am Ws6 M6
    Secondary Air Injection
    I've been having trouble with my AIR system. Car is a 2001 Trans Am Ws6 M6 . I live in California so I need to smog it. I get a P0418 DTC all the time. I've replaced check valves, solenoid, relay, smog pump, and checked all hoses for leaks blockage etc. The car idles high when the solenoid doesn't turn on on cold start. When it does turn on the car idles fine. So after almost 3 months of this nightmare I've came to a conclusion. There is no power going to the solenoid or air pump. I powered the air pump with 12 volts and it works fine and its new. The solenoid sometimes works and when it does the car idles fine but the air pump never turns on so I get a DTC P0418 (secondary air injection relay A bank 1) . So where do I start? Where do I look for a bad ground or loose wire . Where do I start ??????????? Any help anyone !
    I have a new multimeter maybe it could help find a bad wire?
    2001 TRANS AM WS6 M6 . LS1. SLP LTs,SLP cats,SLP catback,SLP Lid,K&N filter, MSD Wires, AC Delco Iridium plugs, Redline Oils and Fluids, Ws6 Store Short Stick, Hotchkis strut tower brace
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Start by checking power at the relay. That'll tell you the direction you need to go. If you've got power at the relay, and then through the relay, you've got a break in the wiring going to the pump. Ensure that the plug connections are good as well.
    The secondary air system should not impact how the engine idles. There is a hose connection over the driver side wheelhouse that you can easily pull apart and check for air blowing on cold startup. The system should only operate for about a minute or so and then turn off. Like Walt said, start by probing your relay for power. If you need schematics posted, let me know and I will gladly do so. Have you by chance unbolted anything from the back of the driver side head? If so, there are ground wires attached back there and it is possible that one is unhooked.
    Mar 2010
    Nor Cal
    How do you check power to the relay? I'm not very savvy when it comes to this electrical stuff. And plug connections are good
    Mar 2010
    Nor Cal
    I would love some schematics. And I always check that hose on cold start up and I never get air blowing from it just air sometimes sucking from the hose connected to the diverter valve.
    Mar 2010
    Nor Cal
    I did notice that the previous owner hooked up a manual fan switch that connected into a harness on the passenger side underneath the hood. I unplugged the harness and found a metal probe thingy to be full of green acid . I cleaned it and reconnected it and nothing
  1. What is the secondary air injection system
    By Street Fighter in forum General Help
    Last Post: 03-21-2015, 08:31 AM
  2. Help: secondary air injection
    By mvinson in forum General Help
    Last Post: 06-09-2012, 05:53 PM
  3. 99 trans am secondary air injection
    By MattB75 in forum External Engine
    Last Post: 01-27-2008, 07:29 PM
  4. Secondary Air Injection System DTC Code
    By Quicksilver Vert in forum Computer & Tuning
    Last Post: 09-03-2007, 05:35 PM
  5. Secondary Air injection codes popping up
    By blackTA6585 in forum General Help
    Last Post: 01-27-2007, 06:12 PM
