    Junior Member Quicksilver Vert's Avatar
    Feb 2006
    CT
    Quicksilver
    2001 Corvette
    Secondary Air Injection System DTC Code
    My Check Engine light is on.I scanned the PCM,and got: DTC P1416 "Secondary Air Injection System,Bank II".
    Which side of the LS1 engine is Bank II?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Quicksilver Vert View Post
    Passenger side.
    Feb 2006
    CT
    Quicksilver
    2001 Corvette
    Thanks Wesman.That should help me narrow things down.
    Senior Member
    Jacksonville, FL
    Had the same code on my car, clogged passenger side air check valve.
    NJ
    SGM
    1998 Trans Am WS6
    No prob
    Feb 2006
    CT
    Quicksilver
    2001 Corvette
    Quote Originally Posted by 2001NBMZ28 View Post
    Where did you find the check valve for the passenger side?
    The check valve for the driver's side is right up top near the exhaust manifold,but I couldn't see the passenger side check valve.
    Senior Member
    Jacksonville, FL
    Did you find it? Don't know if your AIR set up is different - mine screwed into the metal pipe coming off the top/front exhaust manifold, then connected to a hose, right by the #4 cyl coil pack.
    Feb 2006
    CT
    Quicksilver
    2001 Corvette
    Yes,I finally found the bank 2 check valve hidden behind the engine,in the metal piping between the engine and the firewall.The AIR exhaust manifold connection,for bank 2,is a two bolt flange located between cylinders #4 and #6.The bank 1 AIR check valve is right out in the open,behind the alternator.Thanks for your help 2001NBMZ28.
  1. What is the secondary air injection system
    By Street Fighter in forum General Help
    Last Post: 03-21-2015, 08:31 AM
  2. Help: secondary air injection
    By mvinson in forum General Help
    Last Post: 06-09-2012, 05:53 PM
  3. Secondary Air Injection System Bank 1
    By Naaman in forum General Help
    Last Post: 07-09-2011, 07:27 AM
  4. Replies: 7
    Last Post: 08-27-2007, 03:06 PM
  5. Replies: 2
    Last Post: 10-02-2006, 03:54 PM
