Results 1 to 15 of 15
06-29-2011, 08:49 AM #1
Secondary Air Injection System Bank 1
Um... on my way to work this morning, my SES light popped on. I checked the code. P1415.
checked this thread and looks like it could solve all my problems, but even though I keep tools in the car, I don't have replacement parts if that's where the problem is.
I have to pick up my wife for a doctor's appt today. It will be a total of about 65 miles of driving. Do I have anything to worry about? Can I get away with just deleting the codes and worry about it over the weekend?
BTW: for some reason, there are two codes in the sticky: P0410 and P1415.
410 reads: "secondary air injection system."
1415 reads: "secondary air injection (AIR) system bank 1."
Mine is ONLY P1415.Last edited by Naaman; 06-29-2011 at 09:10 AM.
06-29-2011, 10:49 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
It's just the drivers side check valve - fine to drive.
06-29-2011, 11:46 AM #3
yes it is fine to drive. If you don't have smog test in your state. I will have the codes tuned out. I got tired of replacing them. Its fairly easy to do but it was happening too often.
Our sponsor tuner Frost can help you tune the codes out. You just send him your PCM in the mail. Any local tuners can do it for you as well.
06-29-2011, 04:11 PM #4
That's a relief. There is actually no smog requirements in my county, but I will be moving soon. Need to research the emissions laws where I'm going.
06-29-2011, 04:53 PM #5
is that a SOM vert???
06-29-2011, 05:56 PM #6
Agree. The car is fine to drive with a secondary air code tripping the SES.
06-30-2011, 05:46 AM #7
So, if I delete this function will my vehicle fail a smog check? I would love to eliminate as many things from my car as possible that do not contribute to the usability of it, just to reduce complications (one less thing to go wrong).
It's Cayenne Red Metallic (the predecessor to SOM, I think).Last edited by Naaman; 06-30-2011 at 06:41 AM.
06-30-2011, 02:44 PM #8
06-30-2011, 07:03 PM #9
Thanks. I used to hate the color, but it has grown on me a lot. Especially when it's all waxed and the sun is shining.
Well that's good to know. I'd love to delete it. Any idea why it would throw a code after 20 miles of driving? Incidentally, I erased the codes yesterday and they came back on today on my way home from work.
07-01-2011, 09:00 AM #10Member
- Jun 2006
- Newnan, Ga
GM LeMans/Luxo Blue- 2001 Firebird Formula
I had the same AIR Injection problem with my 2001 Formula. Sent my computer to Frost and he deleted the system from the computer. He also deleted the rear o2 sensors as well as a bunch of other enhancements. It will pass emissions. The test will be tricked into thinking they are there and working correctly. Best $150 I ever spent and it only took 2 days turnaround time.
07-01-2011, 10:44 AM #11
07-01-2011, 12:11 PM #12Senior Member
- Jul 2005
- Jacksonville, FL
If P1415 is the only code I'd just replace the valve. Easy DIY and part is not expensive.
07-07-2011, 01:29 PM #13Spaz is My Mentor
yes, but try PB Blaster instead. WD40 doesn't penetrate as well as PB Blaster does. Soak it & let it sit for 10 mins. I've even had stuff sit for a couple of hrs for it to work.
07-08-2011, 07:02 AM #14
07-09-2011, 07:27 AM #15Senior Member
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Check your fuse I had same problem fuse was blowen replaced works fine, Google P1415 it will tell you all you need to know..
What is the secondary air injection system
By Street Fighter in forum General HelpReplies: 13Last Post: 03-21-2015, 08:31 AM -
Help: Secondary Air Injection
By FirehawkM6 in forum External EngineReplies: 5Last Post: 10-15-2012, 09:17 AM -
Help: secondary air injection
By mvinson in forum General HelpReplies: 4Last Post: 06-09-2012, 05:53 PM -
Secondary Air Injection System DTC Code
By Quicksilver Vert in forum Computer & TuningReplies: 7Last Post: 09-03-2007, 05:35 PM -
Help! SES Code P0410 (PCM) Secondary Air Injection System
By dbuie in forum General HelpReplies: 2Last Post: 10-02-2006, 03:54 PM
