Thread: ticking
    Member barryTA's Avatar
    Aug 2006
    ARIZONA
    2001 trans am
    Angry ticking
    has any body developed a sort of loud ticking noise after header install?
    i put the blocking plate in the AIR did every thing right cant see it being
    a header gasket the sound comes from the right side of the car
    maybe it's a lifter out of out of adjustment?
    Member Phlash_riot's Avatar
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    After reinstalling my stock exhaust manifold from a head swap I did I had a loud tickihng and rattling comming form the drivers side. For me what happened was that I did not properly tourque down on of the block-off plates and it was rattling from taht as well as getting exhaust noise from the leak.
    But if you have rechecked that then i would think did you re-use the old header gasket? or did you replace it. Also did you tourque the header down in the proper order? Lastley make sure your collector is tightend down too. G/L
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Plug Wire or Blank-Off Plate
    If you removed the wires make sure they are on with two (2) pops on the connector. Will run that way but tick. A leaking blank-off plate will do the same thing. Make sure a gasket is there and its tight. Good luck
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    Aug 2006
    ARIZONA
    2001 trans am
    im going to check my wires.and block off plate.
    Thanks!!
  1. bad ticking
    By Firebirdformula99 in forum Internal Engine
    Last Post: 04-23-2012, 05:51 PM
  2. Help: ticking??
    By nativetalon in forum External Engine
    Last Post: 02-18-2011, 07:09 AM
  3. Ticking sound
    By GottaHaveLS1 in forum General Help
    Last Post: 09-07-2007, 01:48 PM
  4. ticking
    By stangereater in forum Internal Engine
    Last Post: 09-23-2006, 08:14 PM
  5. ticking
    By daas5 in forum Almost Anything Goes
    Last Post: 04-06-2006, 10:58 AM
