Results 1 to 13 of 13
Thread: Ticking sound
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    Ticking sound
    I was putting my car away this afternoon and I heard a ticking sound when it idles. it's easier to hear if you're right next to the car but not so much when ur in front with the hood open. You can hear it pretty good if you get down and look under the car where the headers collect. It starts up about ten seconds after the car starts. what could cause this? could it develop into anything serious?
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    check the oil level would be my first thing.
    maybe it could be the infamous piston slap?
    00 Z28 M6 T-tops
    00 SS A4 T-tops (Sold)
    99 Corvette M6 (Sold)
    98 Z28 A4 Coupe (Sold)
    98 Z28 A4 T-tops (Sold)
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    Exhaust leak or bad rocker arm in my case
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Back plug wire or header leak?
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    Senior Member
    Jacksonville, FL
    To me an exhaust leak is more of a tapping sound - ticking sounds electrical. Loose plug/wire/something arcing on the header....
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    How long after the headers install did it start ticking?
    Connecticut
    1999 Trans Am M6
    I just noted it yesterday and the tuner noticed it as well. I had it tuned about 2 weeks after the install and I started noticing it yesterday.
    my first thought would be an exhaust leak from the way you describe it. An exhaust leak will sometimes make a ticking sound that sounds like someone pecking on metal with a screwdriver or something like that. If it's less noticeable with the hood up but more pronounced from under the car I would look at the exhaust first. What kind of exhaust clamps did you use and are the headers slip fit or flanged?
    Connecticut
    1999 Trans Am M6
    They're pacesetters... so they're slip fit. I used 3 in band clamps on the two collectors and where the y pipe connects.
    Senior Member 02ultraZ's Avatar
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    watch that piston slap if its right upon start up.
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    http://www.ls1.com/forums/showthread...ht=piston+slap
    In post #11 there is an audio and a video file of the piston slap in this thread, check it out and see if that's the noise you are hearing. My car does it really bad...
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    http://http://ls1tech.com/forums/sho...highlight=crap
    There is a thread that is on ls1tech. Not sure if that is the same noise or not, i can't listen at the moment, i'm at work and don't have any speakers. They state in this thread that it's the lifters...
    Connecticut
    1999 Trans Am M6
    what's piston slap and how bad is it?
  1. ticking sound in a 98 Z71
    By red99ws6 in forum GM Trucks
    Last Post: 09-20-2008, 10:33 AM
  2. LS1 ticking sound stopped
    By wawuzit in forum Corvette
    Last Post: 09-18-2008, 04:06 PM
  3. ticking sound, help!
    By sund0wn in forum General Help
    Last Post: 08-17-2007, 04:25 PM
  4. ticking sound from engine??
    By 1stgto in forum GTO
    Last Post: 06-14-2007, 09:13 PM
  5. Ticking sound just started
    By jtredd in forum Computer & Tuning
    Last Post: 12-05-2005, 02:41 PM
