Results 1 to 15 of 15
    In a house
    04 GTO
    Question ticking sound from engine??
    Hi,
    wondering if any of you have had this experience and if so how did you fix it? I have a 2004 gto with 7500 miles and oil change about 500 miles ago and I always put in 91 octane gasoline. This seems to be intermitent. like if I rev it up then it seems to stop for awhile. Any suggestions would be great.
    Thanks in advance
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Well, with the info given its kinda hard.If its intermitent, its going to be really hard to spot. I hate them damn problems. Anywho, Ide check all your exhaust mount's and then check for random loose shit. Then theres always the, "Ticking noise thats in your head noise"
    Good luck.
    doesn'tplaywellwithothers superchargedblackgto's Avatar
    Mayberry....(Indiana)
    2004 GTO
    It could be spark knock....but hard to tell over net without hearing it....good luck...BTW...LS1 are noisey engines...a little shake rattle and roll is the nature of the beast....if louder than that hard to say
    '04 gto M6 slp ceramic coated headers,B&m sport shifter,harrop cover,3.5"aluminum BMR driveshaft, BMR axle stubs, BMR Half shafts, BMR SFC's, loudmouth2 exaust,90mm FAST T/B,Magancharger(high helix upgrade)......other misc. suspension,Cross drilled, slotted rotors. Meth Kit, spraying @ 3psi and up
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    There are many possiable answers for your sound. Our motors are not the quitest to begin with they have quite a bit of piston slap noise not to mention the injectors and coil packs too.
    I wouldn't worry about it.
    Member Kup98ss's Avatar
    North Carolina
    2002 A4,WS6
    Quote Originally Posted by LS2Tuner View Post
    My guess as well. My T/A makes those sounds. Nothing to worry about.
    In a house
    04 GTO
    Thanks guys, that makes me feel better.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    I got less than 10,000 on mine and it makes all kind of noises since day one.
    Drive it like you stold it they like it!!!!
    SLEEPER GOAT Ls1tiger's Avatar
    Jun 2006
    Wisconsin / Illinois
    Torrd Red
    04 Pontiac GTO
    My EVAP canister purge valve is super noisy when cold. Always has been Sounds like a tick. might be what your hearing.
    Retired Outlaw Sum Bitch
    What oil/viscosity and filter do you have?
    This is my signature. It is mine. Nobody else has one like it.
    south of the border
    2004 GTO
    The LS motors are notoriously noisy so most likely what you're hearing is perfectly normal. Mine has all kinds of ticking sounds with the cam in it. Sounds like a big sewing machine
    2004 GTO M6
    Silver/Red
    K&N CAI
    Kooks LTs w/ Cats, SLP LM 1
    CCW SP500 18X10, 18X8.5, Kuhmo 275/35, 245/40
    GMM Ripshift
    Powerbond UD Pulley
    FTI Rebel TQ Cam
    Member nomorefords's Avatar
    San Diego, CA
    Electron Blue
    2002 EB Z06
    hey man i've got an A4, 2001 z28 and i always hear the same slight knocking sound and constantly check around the headers and i find......nothing! I think it really is "one of those in your head things"! smach that beast out, if it's major you'll know, cause you'll have performance loss that's really easy to notice.
    CASTROville NORTHERN*CALIFORNIA
    Phantom Black
    2004 Pontiac GTO
    my goat makes a ticking noise but you can only hear it thru the wheel well drivers side i already diagnosed it to an exhaust leak, it gets louder as the engine warms up
    Junior Member aus_monaro's Avatar
    Australia
    2002 CV8 Monaro
    mine sounds like a diesel motor on a cold start up...once warms up a bit quiter but stil tick ''tick tick tick'' had her checked out all good, uncle has had may chevs and he reckons sooo many of them still tick!
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    arent you supposed to use 93 octane or higher?!?well for my camaro i have to....
    Australia
    2002 CV8 Monaro
    i wouldnt use ne thing under 98ron fuel mate, its a performance car, why use standard low octane fuel......can only have benefits for the little extra
  1. Need Help - engine ticking sound
    By Flash00TA in forum General Help
    Last Post: 08-25-2013, 02:39 PM
  2. ticking sound in a 98 Z71
    By red99ws6 in forum GM Trucks
    Last Post: 09-20-2008, 10:33 AM
  3. LS1 ticking sound stopped
    By wawuzit in forum Corvette
    Last Post: 09-18-2008, 04:06 PM
  4. Ticking sound
    By GottaHaveLS1 in forum General Help
    Last Post: 09-07-2007, 01:48 PM
  5. ticking sound, help!
    By sund0wn in forum General Help
    Last Post: 08-17-2007, 04:25 PM
