Thread: ticking
04-06-2006, 03:50 AM #1Junior Member
- Apr 2006
- wisconsin
red- 98 ws6 trans am
ticking
Hello every one
I just bought a 98 trans am ws6 with a ls1 motor, The dealer put new lifters in it because it was ticking.It still ticks especially at high rpm's and when the engine is under stress, the noise is constant and unbearable. Any thoughts?
04-06-2006, 05:00 AM #2
rocker, bent pushrod, bad spring, piston slap ? start the process of elimination
04-06-2006, 05:07 AM #3
all LS1's tick, to a certain extent, but pull the push rods, roll them on a flat surface (glass or a mirror) see if they are bent.
04-06-2006, 05:16 AM #4
sounds like it could be spark knock?
04-06-2006, 05:22 AM #5Detailing + Design
- Pittsburgh, PA
sounds like I hope you got a warrenty. Or a proof of service rendered.
Does the ticking increase with RPM's? I bet they didn't replace the damn lifter and just put super-thick oil in it to cover up the sound. Please keep us informed. If they claimed service was rendered, ask to see the service order since their has to be a paper-trail. If they deny you that, have it subpoena'd by small claims. PM a guy named zboner regarding how to proove that work wasn't rendered on your car.
04-06-2006, 05:30 AM #6Detailing + Design
- Pittsburgh, PA
you'd know that as soon as you turned it on
Originally Posted by whitelightnin99
04-06-2006, 08:21 AM #7Junior Member
- Apr 2006
- wisconsin
ticking
Thanks for all the suggestions. I will keep you informed i am betting iti s the lifters or oil pump. i can see that all the gaskets are new so i know the top of the motoe was off, maybe they missed the mark and i am glad i have a warrenty in writing!
04-06-2006, 10:58 AM #8
Check the lifters and rocker lash
bad ticking
By Firebirdformula99 in forum Internal EngineReplies: 11Last Post: 04-23-2012, 05:51 PM -
Help: ticking??
By nativetalon in forum External EngineReplies: 3Last Post: 02-18-2011, 07:09 AM -
Ticking sound
By GottaHaveLS1 in forum General HelpReplies: 12Last Post: 09-07-2007, 01:48 PM -
ticking
By barryTA in forum External EngineReplies: 3Last Post: 01-17-2007, 09:26 AM -
ticking
By stangereater in forum Internal EngineReplies: 14Last Post: 09-23-2006, 08:14 PM
