Results 1 to 3 of 3
    Junior Member winston01's Avatar
    Aug 2006
    Acme,PA
    navy
    2001 TA WS6
    adjusting camber?
    how do you adjust camber on a 98-02 f-body? i know it should be done at an alignment shop but was just wondering.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    lower control arm front bolt. you'll notice the hole is elongated inboard/outboard.
    Yes there sre slots in the K-member for adjustments for camber and caster
  1. Question: Camber adjustment
    By davidz28 in forum Suspension and Handling
    Last Post: 07-07-2011, 01:19 PM
  2. (-) Camber
    By dkishton1486 in forum Suspension and Handling
    Last Post: 04-10-2006, 05:11 PM
  3. camber kit
    By Erik in forum Suspension and Handling
    Last Post: 01-01-2006, 07:24 AM
  4. How to correct Camber
    By WS6ICK in forum Suspension and Handling
    Last Post: 11-25-2005, 04:09 PM
  5. Need Camber Helppp
    Last Post: 11-24-2005, 01:49 AM
