    Nov 2009
    North Carolina
    2001 Camaro Z28
    Camber adjustment
    Ive been reading that adjusting the camber angle to a slightly negative degree so the top of the tire tilts inward is supposed to help with handling, I do alot of autocross and have been rubbing on my side walls and was wondering if this would help? If so how do you adjust it, how much should it be adjusted, and will i need a new alignment after.
    Pittsburgh
    2008 Hummer H3
    I would suggest, better suited tires before fooling around with your alignment @ home..
    Just my .02..
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    You can buy a mount that has a bubble level to give you your camber/toe. I wouldn't try doing it at home w/o that sort of tool though. I don't know the tool name but if you can't find it an alignment shop is your best choice, make sure you get a before and after some shops are lazy. Yes you do want negative camber for turns I have mine at -1.5 and it has quieted down the tire screeching at there maximum slip.
    What size tires you running and where are they rubbing?
    Nov 2009
    North Carolina
    2001 Camaro Z28
    im running 245's they arent rubbing on the car, when i corner had the side wall rolls under and hits the pavement causing the top edge of the side wall to be very worn
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Well my original post was lost but what I basically said was that I would go to a shop and have them adjust the camber as well as the toe and caster. Also if you DD the car I wouldn't go with a super aggressive road racing alignment otherwise you will probably burn your tires down pretty fast when driving on the street.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Bay Area
    my highbeams
    Quote Originally Posted by davidz28 View Post
    Ah gotcha. Even with my -1.5 I still get that, granted it is like that on the inside as well.
  1. Camber Caster Adjustment
    By ponent in forum Suspension and Handling
    Last Post: 02-09-2007, 07:31 PM
  2. (-) Camber
    By dkishton1486 in forum Suspension and Handling
    Last Post: 04-10-2006, 05:11 PM
  3. camber kit
    By Erik in forum Suspension and Handling
    Last Post: 01-01-2006, 07:24 AM
  4. How to correct Camber
    By WS6ICK in forum Suspension and Handling
    Last Post: 11-25-2005, 04:09 PM
  5. Need Camber Helppp
    Last Post: 11-24-2005, 01:49 AM
