Results 1 to 3 of 3
Thread: (-) Camber
    Member dkishton1486's Avatar
    Ohio
    1995 Z28
    (-) Camber
    I have a 1995 Z28 and my camber is (-) Does anyone know where I can get a camber kit at?
    Junior Member DaLastLT1's Avatar
    Chicago, IL
    1997 LT1 Z28
    I don't believe they make camber kits for 93-02 f-bodys.. Camber is adjustable from the factory and should get it back within specs with most drops.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    the factory adjustment is the lower control arm itself. when you say you have negative camber, how much do you actually have???
  1. Question: Camber adjustment
    By davidz28 in forum Suspension and Handling
    Last Post: 07-07-2011, 02:19 PM
  2. adjusting camber?
    By winston01 in forum Suspension and Handling
    Last Post: 01-07-2007, 09:49 AM
  3. camber kit
    By Erik in forum Suspension and Handling
    Last Post: 01-01-2006, 08:24 AM
  4. How to correct Camber
    By WS6ICK in forum Suspension and Handling
    Last Post: 11-25-2005, 05:09 PM
  5. Need Camber Helppp
    Last Post: 11-24-2005, 02:49 AM
