Results 1 to 20 of 33
    386HP 373TQ jwindbigler's Avatar
    San Diego...Michigan originally
    1999 Trans Am 5.7L
    Cam breakin procedure
    Once I have this new cam installed (comp cams 222/224) I would like to know how to break in this cam. I have heard that 20 min at 2000RPM is sufficient. Any thoughts? Thanks
    BOSSONNOS
    AUSTRALIA
    Turismo Blue
    2005 Holden 502rwhp
    LSx engines run roller lifetrs, no need to break in the cam, if anything make sure it's coated in engine oil before you install it or cover the lobes with engine assembly lube just help on start up, other than that, no need to do anything else.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    agreed with above
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Heat cycling the new valvesprings isn't a bad idea.
    But as mentioned...the cam itself needs no break in.
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by jwindbigler View Post
    if you already had the car tuned, there is no need for a break-in period. they wrapped it up to about 6000rpm or so.
    i have a Comp 224 and no break-in was needed for it...
    NY
    yellow
    02 Collector Edition TA
    Yup no break in, its all roller not flat tap which did require break-in. Its more critical now running stiffer springs to let the engine reach operating temps before hammering on it. Stiffer springs = more brittle the metal
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    Question for you guys, I have heard that the new springs need to be warm as stated above, but I am curious as to whether that is everytime the car is turned on you should let the engine heat up to heat the springs or is that supposed to be just the initial start up after springs are installed? Kinda confused on that, different people say different things, hell some say they dont need to heat up at all due to most manufacturers baking them before they sell them.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    Both.
    You want warm springs before going to max RPM's.
    New springs you want to heat them up and then let them cool once. Always make sure you have warm oil up there before spinning it high.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    valve springs these days don't need any heat cycling. the type of steel being used is not the same as he tool steel they used to use years ago.
    now, yes, it's better for the entire engine, mainly cylinder walls, to wait until it's warmed up before beating on it.
    You know...I have heard that several times.
    Still...I think I will heat cycle them once...just to be sure.
    Isn't time consuming or difficult. Piece of mind is all.
    Senior Member Z06-Goose's Avatar
    Colorado
    Avus Silver
    2007 Audi RS4
    Heat cycle!
    The cam itself don't need break-in since it's a roller cam (Hydraulic roller lifters)
    1999 Trans Am 5.7L
    Thanks guys appreciate it!
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    I appreciate the feedback guys.
    i make cars slower s99ta's Avatar
    Iowa
    gas pedal to the floor
    1999 Trans Am 5.7L
    Got the cam installed, it will be ready to crank in a couple of hours
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    SWEET!!!! cant wait till I can post that up.
    1999 Trans Am 5.7L
    Yeah, just as soon as I figure out how to load pics on the site, I will post some!!
    1999 Trans Am 5.7L
    Quote Originally Posted by Wheeler99WS6 View Post
    Where at in Indiana are you??
    I come from a rinky dink town called EDWARDSBURG. Its in Michigan, just north of south bend.
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    Terre Haute its like an hour Southwest of Indianapolis, My brother lives in elkhart though. Its near South Bend.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    NO BREAK IN FOR HYD. ROLLER CAMS.................Take it out and drive it like you stold it!!!!
  1. Mechanical Fuel Injection - Breakin' The Rules
    By Ed Blown Vert in forum General Help
    Last Post: 12-29-2011, 03:50 PM
  2. Top Fill Procedure
    By sjgreen6 in forum Convertible
    Last Post: 09-16-2011, 05:41 AM
  3. How Many do their own oil? What's your procedure?
    By mammoth713 in forum Camaro / SS
    Last Post: 01-24-2011, 01:08 PM
  4. MJ Breakin sales records
    By knightryda01 in forum Almost Anything Goes
    Last Post: 07-02-2009, 07:00 AM
  5. Rear End Gear Breakin
    By GottaHaveLS1 in forum Drivetrain
    Last Post: 05-20-2008, 06:36 AM
