Results 1 to 20 of 63
01-11-2011, 06:50 PM #1
How Many do their own oil? What's your procedure?
How Many do their own oil? What's your procedure to get under the car with enough room?
My car is lowered too, so..?
01-11-2011, 07:01 PM #2
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
My buddy's 99 SS that he just sold, you couldn't get under with a floorjack, so somebody had to lift up where the t-top was, with their shoulders, in order for the car to clear the jack. At that point, I would let it down when he positioned the jack to the point in which the SFC points were welded.
This would be right behind where the front fender lips in, and underneath the car. MAKE SURE you do not jack it up from there though!
Drain plug is on the driver's side, so I always jack up mine from the passenger side. Filter, Oil, 15 mm wrench, and a funnel/filter wrench if you're not good like meJK
2000 Z - Light Pewter Metallic - A4 - 130k - Bolt Ons - My Pride and Joy
2002 C5 - Electron Blue - M6 - 32k - My Dream Car
01-11-2011, 07:50 PM #3
01-11-2011, 08:01 PM #4
Drive it up on a set of 2x4's. That'll give you enough room to get a jack under there.
01-11-2011, 08:49 PM #5
yeah mines lowered an inch and 3 quarters its a task to get it up on jacks but i always have a low profile jack on the side then jack it up a bit then get a bigger jack on the k member then raise it up that way, always put it on stands though the low profile jack has failed on me before luckily i wasn't under it cause it can kill you pretty easy
driving it up on two by fours will work pretty easy too, never tried it though.
01-11-2011, 08:57 PM #6
- Aug 2007
- Texas
i pull the e-brake, raise both sides, put jack stands under it, remove the jack, crawl under, pull the plug, drain, replace the plug, pull filter, replace filter, lower car, refill
let it idle a few minutes, then check the level.
01-11-2011, 10:03 PM #7
1) Slightly warm up the engine.. Then shut off and wait ~5 mins for the warm oil to head back to the pan..
2) Drain oil, and remove the filter. Wiping the filter flange off with a lint free rag..
3) Add one quart with the drain plug left open to flush the pan..
4) Clean the opening and plug then install the pan plug..
5) Oil the new filter seal, fill filter with fresh oil and quickly install..
6) Fill, double check level, and start it up for a couple of minutes..Last edited by Smittro; 01-11-2011 at 10:14 PM.
01-11-2011, 10:07 PM #8
- Aug 2007
- Texas
whats the point off wiping off the filter flange, if you just put oil back on the filter seal
01-11-2011, 10:19 PM #9
01-11-2011, 10:31 PM #10
- Aug 2010
- SF Bay Area
Red- 2002 Camaro SS LE
That's a new one. First time I ever heard of this. I've changed a lot of oil in my lifetime and have never done this. What oil do you use? So you just basically burn a quart? I would think the fresh filter would be enough.
01-11-2011, 10:39 PM #11
- Aug 2010
- SF Bay Area
01-11-2011, 10:41 PM #12
01-11-2011, 10:45 PM #13
I drive up on 2X4's to get the extra height I need to get a floor jack under it. My car is lowered on Strano's. I then always use jack stands to secure it before crawling under there.
01-11-2011, 10:45 PM #14
01-12-2011, 01:15 AM #15
01-12-2011, 02:44 AM #16
1. Drink a beer
2. Drive car up on 2x12
3. Drink a beer
4. Use small jack under frame rail to lift car a few inches
5. Drink a beer
6. Put low profile jack under K-member and raise
7. Drink a beer
8. Put jack stands under car
9. Drink a beer
10. Get oil, filter, rags, and filter wrench ready to go
11. Drink a beer
12. Remove oil drain plug
13. Drink a beer
14. Drink a beer
15. Drink a beer
16. Remove filter
17. Drink a beer
18. Put drain plug in and new oil filter on
19. Drink a beer
20. Put oil in car
21. Drink a beer
22. Get car off stands and back onto ground
23. Ask wife to drive to store to get more beer.
01-12-2011, 04:17 AM #17
01-12-2011, 05:25 AM #18
01-12-2011, 07:28 AM #19
make sure she is nice and warm the oil flows good. put it on my lift
let it drain for 45 minutes or so. brake clean the filter flange. fill my pf61e with new oil and put her all back together. fill with oil, start it and left oil pressure build up. kill it and check level. then she done. then i print me out a snazzy lil oil reminder tag
01-12-2011, 07:55 AM #20
Idle setting Procedure?
By Z34LS1 in forum General HelpReplies: 7Last Post: 07-27-2012, 09:04 AM -
Top Fill Procedure
By sjgreen6 in forum ConvertibleReplies: 10Last Post: 09-16-2011, 05:41 AM -
Help: Break in procedure on a new cam?
By Mr. D in forum Internal EngineReplies: 3Last Post: 06-14-2010, 11:14 AM -
Cam breakin procedure
By jwindbigler in forum Internal EngineReplies: 32Last Post: 01-15-2007, 06:51 AM -
Need detailed procedure on how to swap cams
By jwindbigler in forum Western MembersReplies: 16Last Post: 12-29-2006, 07:12 PM
