Thread: Sway bars
    displaced Texan 418LS1's Avatar
    Williamsburg, VA
    2000 Chevy Camaro Z-28
    Thumbs down Sway bars
    Upgrade or not? What are the benefits?
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    I would suggest upgrading the front to a 35mm Strano bar, leave the rear be. The 35mm bar helps improve handling in those curves. 35mm costs a pretty penny, but I've never read a bad review on one. Me personally, I went with a 1LE 32mm bar because I got it for free. Put that on in place of the stock 30mm and I couldn't believe the diff 2mm made. It was slight, but it WAS there.
    Senior Member Carlos01SS's Avatar
    Aug 2003
    Cypress, CA.
    Quote Originally Posted by 418LS1 View Post
    Depends on what your plans are for your car...
    For the drags, larger rear sway bar is the best way to go...
    For the twisties, Hotchkis front & rear is popular, but not cheap, heavier than Sam Strano's hollow 35mm fronts and hollow 22mm rears, excellent way to go.
    The Black 2001 SS #5697
    T-tops, 6-spd/B&M ripper, ARH LT's/GMMG/CME, Volant, Koni DA's & GC coilovers, Strano frt & rear sways, G2(SFC's w/v-braces, STB, adj PHR), Wilwood 6-piston red calipers frnt brakes w/13" 2-pc rotors, RKSport(clear front & rear corners, c-f grill), chrome Z06 wheels
    Williamsburg, VA
    Thanks fellas. I am probably going to go with the Hotchkis now. I like the curves too much...
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    you have to ask yourself how is the present state of your car's handling.
    is it neutral, understeering, oversteering ?
    Which sway bars you have in the car ?
    From the above answers, you can tell in which direction you want to go.
    remember that swaybars aren't a thing of bigger is better... it's a balancing act of front/rear rates to have the car react as we want it to.
    Eugenio_SS
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    I did the Strano sway bar kit 35 front 22 rear and it is really good. From what I have all read the solid bars really are not better than hollows. I guess it's the out side of the bar that does the work and not the center.
  1. 4th Gen Sway Bars on a 3rd Gen?
    By The Project in forum Suspension and Handling
    Last Post: 10-11-2008, 08:04 AM
  2. MAf,AGX rear shocks, Strano sway bars,1LE sway bar
    By AFASTYZFR1 in forum Parts For Sale / Trade
    Last Post: 09-21-2008, 01:54 PM
  3. Sway Bars
    By OnEbAdReDSS in forum Suspension and Handling
    Last Post: 05-12-2008, 09:26 AM
  4. Best Sway Bars
    By siggs229 in forum Suspension and Handling
    Last Post: 06-06-2006, 11:42 AM
  5. Sway Bars
    By AFASTYZFR1 in forum Suspension and Handling
    Last Post: 06-05-2006, 10:00 AM
