Results 1 to 13 of 13
Thread: Sway Bars
    TECH Fanatic AFASTYZFR1's Avatar
    USA
    Sunset Orange
    2001 Procharged Camaro SS
    Sway Bars
    Are Eibach sway bars any good?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    sure
    Member BitViper's Avatar
    Sandy Ego Ca
    Yellow
    ZO6 Corvette
    what size are they.... if they're 32 front 21 rear..you might wanna look at a set of stock SS bars...could save you some money..
    I believe the stock SS bars are 32 front and 21 or 22 rear
    USA
    Sunset Orange
    It says they are 35mm front and 25mm rear
    Senior Member Corona-Extra's Avatar
    Houston Texas
    Black SVT & Silver WS6
    2003 SVT Cobra & 2002 WS6
    so.. theoretically, if you have a SS or WS6, you dont really need to replace the sway bars???
    No replacement for displacement.
    No 55mph 1QuikWS6's Avatar
    USA
    2000 WS6 Trans Am
    25mm too big for rear bar - will make the car 'tail happy' go with 35mm front/21 or 22mm rear. Hollow bars will also save you weight over the solid versions.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    Eibach sway bars are 35/25.
    What springs are you running ?
    You need to be settled on the spring rates you like and then do swaybars, because it affects the spring rate when cornering, affecting the balance of the car.
    So before we give you advice, you should tell us what springs/shocks you are using.
    If by any chance you have stock springs, I'd suggest getting a big 35 front swaybar and keep rear stock one.
    Eugenio_SS
    USA
    Sunset Orange
    I have KYB AGX struts and hotchkis springs
    Junior Member siggs229's Avatar
    NEW JERSEY
    2002 Camaro SS
    Quote Originally Posted by BitViper
    Stock SS sway bars are 30 F 19 R I should know I have a 2002 SS in my garage I also just upgraded the sway bars .The 1LE package which was done by SLP had 32 F 21 R . Just thought you would like to know .
    Rob
    Junior Member billyb's Avatar
    seminole fl.
    2002 firehawk
    sway bar
    ????????? what is tail happy ?????????????
    Member Bowtie Guy's Avatar
    North San Diego County,CA
    2002 Z28 M6
    Tendancy to oversteer.
    Bowtie good! Blue oval not so good! Bob in the PRK
    seminole fl.
    2002 firehawk
    Quote Originally Posted by Bowtie Guy
    o-i-c.
    coolformula
    Guest
    Check out strano hollow bars 35mm and 22mm
  1. 4th Gen Sway Bars on a 3rd Gen?
    By The Project in forum Suspension and Handling
    Last Post: 10-11-2008, 08:04 AM
  2. MAf,AGX rear shocks, Strano sway bars,1LE sway bar
    By AFASTYZFR1 in forum Parts For Sale / Trade
    Last Post: 09-21-2008, 01:54 PM
  3. Sway Bars
    By OnEbAdReDSS in forum Suspension and Handling
    Last Post: 05-12-2008, 09:26 AM
  4. Sway bars
    By 418LS1 in forum Suspension and Handling
    Last Post: 08-22-2007, 10:38 PM
  5. Best Sway Bars
    By siggs229 in forum Suspension and Handling
    Last Post: 06-06-2006, 11:42 AM
