Thread: Best Sway Bars
    Junior Member siggs229's Avatar
    NEW JERSEY
    2002 Camaro SS
    Best Sway Bars
    What sway bars are the best . I want to upgrade my sway bars . Ive been looking at alot of differnt brands . I think I have it down to 2 . Let me know what you guys think . Im going to include a link to a page that compairs the two of them side by side . I have few Spohn parts on my car now , Adj P H bar , LCA , SFC . The other company is Eibach . I figured they make the springs on my car ( 2002 SS ) so it should work well with it The Eibach sway bars are 35mm 25m . Spohn's are 32mm 22mm , but the Spohn's are made out of chrome moly ... Thanks for the feedback. Here is a link .
    http://byunspeed.com/compare.php?col...0572eec4544f8d
    Rob
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    most swaybars are good in quality.
    It's just a matter of chosing the right size.
    As for best, try asking what is the best cam in the engine section... same thing can be said about springs.
    Having said that, the sway bars will dictate the balance of your car based on the springs you have.
    So, what spring rates you gonna have in your car before you install the swaybars ?
    swaybars is not one of those things that bigger is better... it's all about balance.
    Since you mention Eibach springs, chances are you are talking about the Prokits.
    The prokits work well with the 35/21 and 35/19 combo.
    Going too stiff in the rear will make the rear end very tail happy, and will actually hinder your cornering abilities.
    Eugenio_SS
    Junior Member billyb's Avatar
    seminole fl.
    2002 firehawk
    sway bar
    hi what if the sway bar is adjustable, more/less tension and you could adj. to the springs,tires,track,and = launching???? imo.
    JAMES RODRIGUEZ
    Guest
    I run a Hotchkis 36.5 front with a Spohn 22 rear. The combination works great.
    wow! that'a massive sway bar!
    Junior Member baker5209's Avatar
    Mich
    1998 Z28
    Thumbs up
    Glad i read this post. Was wondering the same my self which to get
    JAMES RODRIGUEZ
    Guest
    With the bars I listed there will be no sway in the car at all. It will corner flat.
    Member BitViper's Avatar
    Sandy Ego Ca
    Yellow
    ZO6 Corvette
    Quote Originally Posted by billyb
    hi what if the sway bar is adjustable, more/less tension and you could adj. to the springs,tires,track,and = launching???? IMO.
    Never heard of one that was adjustable..
    Member 99SS'Vert's Avatar
    Wylie TX
    '99 Camaro SS
    The Spohn's seem to do real well with the Eibach pro-kit. I feel like the car has a nice balance at the limits.
    I did however switch out to the Edelbrock IAS spring and shock combo and that killed the handling. So I'll be going back to the Eibach and SLP Bilsteins setup.
    '99 SS 'Vert M6 - Lid, TB, LS6 Int., Mac LT's w/ORY, Corsa Exh., Textralia Hybrid w/Billet Fly., Edelbrock IAS F/R, LCA's, STB, Tq. Arm, Baer GT+ Kit, 17x9.5 & 17x11's, Wolfe 6-Pt. Cage.
    www.keithcraftmotorsports.com
    [email protected]
    NEW JERSEY
    2002 Camaro SS
    Where did you get the rims ??? And how much ?
    Rob
    Marylandistan
    2001 Trans Am (sold)
    Quote Originally Posted by dipherentdesign
    The Hotchkis front bar is hollow and therefore lighter than the Spohn one with similar performance. Not cheap tho.
    coolformula
    Guest
    Depends on what you want to do.
    Stock springs? Shocks?
    Strano hollow bars are light close to the stock bar...
    ST bar is good too but HEAVY..30 pounds.
  1. 4th Gen Sway Bars on a 3rd Gen?
    By The Project in forum Suspension and Handling
    Last Post: 10-11-2008, 08:04 AM
  2. MAf,AGX rear shocks, Strano sway bars,1LE sway bar
    By AFASTYZFR1 in forum Parts For Sale / Trade
    Last Post: 09-21-2008, 01:54 PM
  3. Sway Bars
    By OnEbAdReDSS in forum Suspension and Handling
    Last Post: 05-12-2008, 09:26 AM
  4. Sway bars
    By 418LS1 in forum Suspension and Handling
    Last Post: 08-22-2007, 10:38 PM
  5. Sway Bars
    By AFASTYZFR1 in forum Suspension and Handling
    Last Post: 06-05-2006, 10:00 AM
