Results 1 to 20 of 25
12-17-2006, 06:20 PM #1Member
- Ohio
Black- 97 Formula
Changing jounce bumper/bump stops???
I was flipping through the new SLP catalog when I saw the part about jounce bumpers for 17" wheels. It says they are needed when upgrading a 16" wheel car to 17" wheels. My car rides a little harsh [mods in sig] on these damn Ohio roads. So I was wondering if I got the new bump stops, would they make any difference in reducing the ride harshness? I would think that would allow a little more axle travel. I was thinking of getting them if my stock bumpstops are torn up.
12-18-2006, 07:52 AM #2MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
I don't think you should be hitting the bump stops just driving on crappy roads unless you are one of them DUKE boys jumping things.
12-18-2006, 08:19 AM #3M6 King
- Mar 2006
- WI
- Blog Entries
- 1
They are bigger and will give you less suspension travel. I trimmed mine down for a little extra travel.
12-18-2006, 06:19 PM #4Member
- Nov 2006
- Earth
If your overall tire diameter hasn't changed from 26.1 then the suggestion to change the bump stoppers doesn't make sense to me. Spring / shock travel is unaffected.
I replaced the stops on my 95 because the rubber had torn away from the mounting. Factory replacements were $20 each at significantly discounted pricing.
12-18-2006, 06:37 PM #5Just me
- Nov 2006
- Broken Arrow, OK
I just bought new bump stops from GMdirect, they were $45 shipped. Mine were extremely worn down. You should be able to look at your current bump stops and be able to tell if they need replacing. I don't see a reason to honestly get the jounce bumpers unless you plan to get 17" inch wheels in the future.
Are you lowered at all?
12-19-2006, 05:07 AM #6Member
- Ohio
Black- 97 Formula
My car had 245/50/16 on 16" stock. I upgraded to 275/40/17 on 17" WS6 wheels, and lowered my car on factory WS6 springs. Just trying to see if there was anything I could do to soften my ride a little.
12-19-2006, 06:47 AM #7Member
- Nov 2006
- Earth
If you are hitting your jounces regularly then you are probably passing a little blood from your kidneys as well. Even though I drive the worst roads in the US, the jounces rarely (if ever) have made contact with the axle. My jounces had no wear on them after 100k miles. They came apart from rust. If you want a softer ride you definitely don't want a lowered car; my lowered 01 literally beats the piss out of me. When tire profiles get to the point when they have 3-4 inches of rubber from road to rim, you have very limited sidewall deflection and nothing in regard to shock absorption as you already realize. Besides the lowering from your suspension, your car also sits .25 inches lower due to the 40% tire profile. Sam Strano is the suspension expert that I know of. Maybe he can help.
12-22-2006, 01:44 PM #8Crazy Canuck !
- Jun 2002
- Montreal, CANADA
don't waste your $... it's worse with the jouncer spacer than without and the SS bumpstop makes a worse job than the Z28 version... trust me on this one... ppl that race for handling, if they have an SS, they swap for the Z28 version.
Leave it as is.Eugenio_SS
12-23-2006, 12:08 PM #9Member
- Ohio
Black- 97 Formula
ok,thanks
01-01-2008, 05:32 PM #10
01-01-2008, 05:36 PM #11Just me
- Nov 2006
- Broken Arrow, OK
10164173
01-01-2008, 05:37 PM #12
04-30-2009, 07:21 PM #13Junior Member
- Apr 2009
- New Jersey
Silver- 2000 Camaro Z-28
Help !!!
My rear jounce bumpers on my 2000 Z-28 are toast!
GM is out of stock on them!!
Does anybody know of a manufacturer that makes rear jounce bumpers for a 2000 Z-28??
Please get back to me: [email protected]
Thanks!
4/30/09
04-30-2009, 07:48 PM #14Slow'er'Ass
- Thornton, CO
Mine aren't on the car anymore....
05-03-2009, 06:10 PM #15
05-03-2009, 06:16 PM #16
05-03-2009, 06:18 PM #17
05-03-2009, 06:20 PM #18Impounded
- Oct 2007
- Beaver Dam KY
here is a cheap route guys
http://www.ls1.com/forums/showthread.php?t=112720
05-03-2009, 06:21 PM #19
05-04-2009, 03:49 PM #20
My car has the metal plates between them.
Bump stops
By MeanMachine1 in forum Suspension and HandlingReplies: 4Last Post: 09-16-2012, 05:46 AM -
Bump Stops
By bad4ss in forum Suspension and HandlingReplies: 23Last Post: 03-14-2011, 10:11 AM -
Question: bump stops
By JoshuaGrooms83 in forum Suspension and HandlingReplies: 4Last Post: 11-24-2010, 08:01 PM -
Bump stops
By jd2002ss in forum Suspension and HandlingReplies: 3Last Post: 10-30-2009, 01:02 PM -
Question: Bump Stops
By Fastdaddy in forum Suspension and HandlingReplies: 5Last Post: 05-13-2008, 05:08 PM
