Thread: Bump stops
    Mar 2012
    MICH
    Black N Gold
    02 WS6 / Ls6 with mods.
    Bump stops
    When grinding on rear bump stop brackets do you relocate mounting holes also ? Can see where rim is hitting ( approx 12" wheel ) on brackets . Currently running new Bilsteins and new Moogs , going for decent ride .
    are you using stock bump stops or Strano Bump stops ($28)?
    Mar 2012
    MICH
    Black N Gold
    Using stock bump's , had wheels off today and ground off some metal . Prob not enough though did'nt have right gringer also took spacers off . Could see where tire rubs on wheel well in a couple spots , did'nt have a BFM .
    Mar 2012
    MICH
    Black N Gold
    Correction 10" wheel
    Quote Originally Posted by MeanMachine1 View Post
    I only had to grind the flange on the body down. Never had to touch the bump stops as Isimply remove them when I mount the track wheels. I have not heard of anyone relocating the bolt holes, but I suppose you could. Other option would be to attach a bump stop to the axle using aftermarket pieces.
  1. Bump stops wanted
    By LETHALxLS1 in forum Parts Wanted / Trade
    Last Post: 11-14-2012, 08:16 AM
  2. Bump Stops
    By bad4ss in forum Suspension and Handling
    Last Post: 03-14-2011, 10:11 AM
  3. Question: bump stops
    By JoshuaGrooms83 in forum Suspension and Handling
    Last Post: 11-24-2010, 08:01 PM
  4. Bump stops
    By jd2002ss in forum Suspension and Handling
    Last Post: 10-30-2009, 01:02 PM
  5. Question: Bump Stops
    By Fastdaddy in forum Suspension and Handling
    Last Post: 05-13-2008, 05:08 PM
