Thread: bump stops
11-23-2010, 02:00 PM #1
bump stops
Do i need new ones? and does it matter if i get Poly Bump Stops? Do you need them if you get wider tires/bigger diameter? Just wondering since i was under there and now that i have lowered my car does anything need to be done with them?
11-24-2010, 11:27 AM #2
Your bump stops look fine in your other thread with the spring install.
2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
11-24-2010, 11:54 AM #3
ok, wasnt sure. ive come across a few of them on websites that mention that you need them for 17" rims. i wasnt sure if i needed them.
11-24-2010, 02:02 PM #4
For my drag wheels, I ground the lip back on the mounts and I remove the aluminum spacers when I go to the track. This gives just a bit more sidewall clearance. Probably not required -- but it was simple to do and peace of mind is a good thing.
11-24-2010, 08:01 PM #5
I took the spacers out because I got tired of the car slamming on the rear end everytime I hit a bump on the freeway
Bump stops wanted
By LETHALxLS1 in forum Parts Wanted / TradeReplies: 1Last Post: 11-14-2012, 08:16 AM -
Bump stops
By MeanMachine1 in forum Suspension and HandlingReplies: 4Last Post: 09-16-2012, 05:46 AM -
Bump Stops
By bad4ss in forum Suspension and HandlingReplies: 23Last Post: 03-14-2011, 10:11 AM -
Bump stops
By jd2002ss in forum Suspension and HandlingReplies: 3Last Post: 10-30-2009, 01:02 PM -
Question: Bump Stops
By Fastdaddy in forum Suspension and HandlingReplies: 5Last Post: 05-13-2008, 05:08 PM
