    Member Huskerz1's Avatar
    99 SS Vert M6
    Engine stuttering
    Just changed plugs and wires. Motor idles fine but stutters when at a stop light and at take off. Any suggestions? Do I need to reset the PCM or recheck my plug gap?
    Indianapolis
    2000 WS6 6spd Hooker LT
    More info please. Was it doing this before you did anything? If not, the first thing to check would be that you have the plug wires on correctly. It is possible to think they are on the plug, but not exactly.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Did it have the issue befor you changed the plugs and wires? like said above first make sure all of your wires on on tightly, you should hear two snaps when connected. If you still have the issue pull the plugs out and check for gap. Did you gap them or did they come pre-gap'd?
    Also check the condition of the wires, make sure there not melted and so forth.
    J
    99 SS Vert M6
    No stuttering before the plugs and wires. I'll check the wires.
    99 SS Vert M6
    Good News! Ole #8 needed another click. My motor was still kinda hot when I changed plugs and wires so I used gloves. I must not have gotten #8 on enough. It clicked on once more when I checked it cold today. Things are smooth now.
    Thanks
    Indianapolis
    Kewl!
  1. Engine stuttering at Idle
    By mike171562 in forum General Help
    Last Post: 04-01-2010, 12:03 PM
  2. Stuttering?
    By LgndKller20073 in forum General Help
    Last Post: 11-08-2009, 07:01 AM
  3. Stuttering problem
    By Ramairgod84 in forum Corvette
    Last Post: 10-23-2008, 03:18 AM
  4. here is a video of my car stuttering?
    By Justin23454 in forum General Help
    Last Post: 01-21-2008, 06:08 PM
  5. Stuttering problem
    By 00vettecovert03red in forum General Help
    Last Post: 09-16-2005, 04:31 AM
