Results 1 to 2 of 2
Thread: Stuttering problem
09-28-2008, 07:00 AM #1
Stuttering problem
hey all, I just recently did the haltech ram air tunnel port mod and cut behind my plate to let air into the engine compartment. I noticed a good difference in power, but at cruising speeds the car seems to stutter a bit. Almost hesitate when applying the throttle. I've got headers, exh and a blackwing. The only other thing is I de screend the maf. Any thoughts on what the stuttering could be?
10-23-2008, 03:18 AM #2Member
- May 2007
- Seattle
Jetstream Blue Metallic- 2008 Z06 Corvette
Did you descreen the MAF at the same time you installed the ram air? Were you really careful when you did descreen it? I know those things are super sensitive. You may now be getting a low voltage reading on it. I was told by my tuner that on Vette's and Camaro's it is not advisable to remove the screen because it's a straight shot right through them, whereas on the trucks for example, it is advisable because they are at an angle.
Just his advice, not mine, because I removed mine [the screen] on my SS Camaro while installing a SLP cold air induction kit, and wound up having to replace the MAF after doing so.
Stuttering?
By LgndKller20073 in forum General HelpReplies: 18Last Post: 11-08-2009, 07:01 AM -
Stuttering and lunging
By knewsock in forum General HelpReplies: 1Last Post: 04-04-2008, 07:20 AM -
here is a video of my car stuttering?
By Justin23454 in forum General HelpReplies: 4Last Post: 01-21-2008, 06:08 PM -
Engine stuttering
By Huskerz1 in forum General HelpReplies: 5Last Post: 12-18-2006, 03:43 PM -
Stuttering problem
By 00vettecovert03red in forum General HelpReplies: 5Last Post: 09-16-2005, 04:31 AM
