Results 1 to 20 of 26
    Member mike171562's Avatar
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    Angry Engine stuttering at Idle
    I washed my engine bay 3 days ago and now my engine is stuttering at idle. I used plastic bags to block off, the PCM, Fusebox, and electrical connectors first, just used a regular garden hose on a cold engine, when i finished, i started the car and let it reach operating temp and turned it off. The car runs fine until it warms up as soon as it starts reaching operating temps, it starts to randomly stutter so I'm thinking maybe my o2 sensors? Before this it was running fine, Spark Plugs, wires, and fuel filter were changed last week before this happened. anybody got any ideas? this is really pissing me off there are no engine codes or lights
    Sep 2009
    Maine
    2002 pontiac Trans Am Ws6
    I doubt its the water. I wash my engine all the time and never use any bags, check your fuel pressure. It should say 55psi to 60psi. Any problems cranking it up?
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    No, it cranks fine and runs smooth until the temp guage starts to rise. It was running fine before i got it wet, how do you check your fuel pressure?
    Sep 2009
    Maine
    So when the car starts running hotter, it runs like crap?
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    it never gets hot, just normal operating temp around 180-190, when the temp guage starts to rise is when it start happening, when i first start it up, it idles smooth, i just changed my plugs and wires so i dont think its a misfire, dont really want to pull them all off again unless i have to, i still got the cuts on my hands from doing that, i tried unplugging the maf for a few minutes , but it didnt change anything.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Usually in a situation like this where you wet down the engine and it misses, its ignition system related. The plugs wires usually. You say they are new...so that shouldn't be an issue. Things should eventually dry out.
    Sep 2009
    Maine
    Take your spark plug wires off and your plugs and see if any water got to them. The easiest way to change plugs on a Ls1 is to take the ignition coils off first, that will give a little bit more space and saves you from getting your hands cut all up.
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    I noticed my throttle position sensor wires were exposed at the plug and touching each other, i taped them off, but its still doing it, also noticed this morning, my a/c vents are blowing on the floor and not out the main vents, this means a vacuum leak correct? could this be the cause of my issue?
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    coolant temperature sensor could also be a culprit.
    Member stew215's Avatar
    Dec 2009
    Levittown, PA
    A vacuum leak will definitely make the car surge. I am not sure if that would be related to the vent not working.. Hopefully some one will have an answer for you.
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    Quote Originally Posted by needls1again View Post
    i replaced the temp sensor on the engine block by spark plug number 1, it broke when i was doing the plugs, driving home in traffic yesterday, i noticed it starts when i stop the car and let the idle fall below 600 rpms or so, if i keep it under a light load and just coast at 900+ rpms it runs ok, its like its idling too low , when i stop it idles around 600 and thats when it starts stuttering, its got to be a closed loop issue, it idles fine for the first few minutes after i start it.
    Sep 2009
    Maine
    Hmmm....i would say drive up here, and my buddy could look at it. He is a badass mechanic and would have that issue fixed in no time, but it would be a 3 hour drive.
    Mar 2010
    arizona
    1971 C-10 ls1 engine
    I swapped a LS1 into my 71 Chevy Truck and I am having the same problem. I took the engine to the car wash before installing it and hosed it off too. I have the same exact problem. What was the fix? Did you ever get it resolved?
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    not fixed yet, im still living with it and dont have the money to start throwing parts at it. i drove around with an ODB II reader and recorded a bunch of data, but its nothing useful
    Sep 2009
    Maine
    Check your fuel pressure...when my fuel pump was acting up it would drive normal in the high RPM's, but when i come to a stop in the low RPM's it would stutter and wanting to turn off.
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    would that explain why it only happens after the car warms up? any way to check it without buying a pressure guage, I'm broke at the moment
    Sep 2009
    Maine
    no you have to have the gauge...most mechanics check that for free. It wont even take a min to hook up the gauge and check the pressure.
    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    you can rent a pressure gauge from auto zone. you just have to put up the cash and they give it back to you when you return the tool
    Feb 2010
    Houston, Tx
    1998 WS6 T/A
    Ok, i unplugged both my front o2 sensors and drove around and the problem seems to have disappeared. The bucking at idle stopped and seems to drive smoother. Guess this means my o2's are bad? Is it ok to drive around with them unplugged for a few days until I can get replacements?
    Feb 2008
    scranton,pa
    i dont know for sure but i dont imagine that being to healthy for your engine. the front 02 sensors read the exhaust to make adjustments to your air fuel ratio at the bare minimum it will deffinatly kill yor gas milage, i dont know man if it was your rears i would say yeah no big deal, they just monitor that the cat is working correctly. maybee somone else can chime in hear and let us know if its ok or not. but if it was me i wouldnt
  1. Help: Hign engine idle
    By austen.holton in forum General Help
    Last Post: 04-19-2010, 06:39 AM
  2. Engine Won't Idle
    By kempfer99ta in forum Classic Muscle
    Last Post: 01-24-2010, 04:57 AM
  3. Engine races At Idle
    By midnitejam in forum General Help
    Last Post: 05-13-2009, 01:36 PM
  4. Engine stuttering
    By Huskerz1 in forum General Help
    Last Post: 12-18-2006, 03:43 PM
  5. engine idle trouble help!
    By larryndog in forum General Help
    Last Post: 07-20-2006, 12:32 PM
