    dayton
    02 firebird
    engine idle trouble help!
    my 02 firebird idles rough with a/c on what do i do?
    Senior Member
    Jacksonville, FL
    How bad? You mean just different? With the AC clutch engaged and fans at high speed at idle it will put more of a load on the motor/electrical system. Throwing any codes?
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    what's done to your car, stock? I'm having the same problem, but it's because of the cam, and I haven't quite perfected the idle w/ac in the tune.
    She's baaaaaccccck...
    '02 Z/28 M6 Hardtop
    dayton
    02 firebird
    yeA IT STOCK
    Northern VA
    Dark blue metallic
    1999 Camaro SS
    How many miles? If the car is stock it should idle fine with the A/C on, so it could be extra drag caused by the clutch or possible some other items.
    Would the idle air control valve effect this? If it's dirty it will cause rough idle.
    Part of basic maintenance on most EFI cars these days is to clean items such as the IAC. They often get caked with carbon and other deposits.
    The IAC is the round item bolted to the right side of the throttle body, towards the top with a wire connector on it. It's removed with two torx screws. Be careful to note the location and presence of the o-ring for reinstallation.
    I usually just spray them with a good stream of carb cleaner or brake cleaner to remove the deposits. I've seen some so bad they were basically stuck in a certain position and caused the car to not idle, a simple cleaning was all it took.
    How many miles on the car?
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    When was the last time you changed your fuel filter and cleaned your fuel injectors?
    dayton
    02 firebird
    it a 25k miles
  1. Trouble Starting, High Idle, Can't go to work...
    By justinmc978 in forum Firebird / WS6
    Last Post: 12-29-2010, 05:53 PM
  2. engine trouble
    By 98bird in forum Internal Engine
    Last Post: 04-02-2009, 10:12 AM
  3. Check engine trouble
    By tals199 in forum Computer & Tuning
    Last Post: 02-02-2008, 04:42 PM
  4. 98 Z28--idle Trouble Again!!!!!!wtf!!!!
    By LETHALxLS1 in forum Camaro / SS
    Last Post: 02-23-2007, 10:12 AM
  5. Engine trouble shooting HELP
    Last Post: 03-06-2006, 12:19 PM
