Results 1 to 11 of 11
Thread: throttle body question
12-15-2006, 07:15 PM #1Fairies Drive Imports
- Apr 2006
- Clarksville, TN
Sunset Orange Metallic- 2002 Camaro SS M6
A friend of mine told me that an 80mm TB from a 6.0L Chevy pickup will bolt right on to the LS1. This would be a cheaper upgrade than to buy a 90mm TB from some other aftermarket retailer, especially if I port and polish it myself. Anyone have any feedback on that?
12-16-2006, 10:39 AM #2
Why not just port and polish your stock 78mm to make it 85mm?
12-16-2006, 04:55 PM #3Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
normally if you port your stocker you are usually only adding about 3mm to it and that is only done mainly around the outer portion, dont want to take it in to far I would think. If you took it to 85mm would you not have to change the linkage so you could fit a bigger blade in it?
1999 T/A WS6 Black
-------SOLD
05 mustang Roush sport;
DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
12-17-2006, 03:12 PM #4
Well im not sure, its just that i had heard of a ls1 speed shop near my house porting stock tb's to 85mm. I mean thats just what they say, but i wouldn't think they would be lying about it either.
12-17-2006, 05:43 PM #5Senior Member
- Jul 2006
- indiana
They probably are not lying, perhaps they change the linkage and blade when they do it.
12-17-2006, 06:11 PM #6King 0f n00bz
- Jan 2006
- Shepherd, Michigan
be carefull with swaping out TBs alot of people have problems with how the engine runs after they are on. not to mention the stock can handle around 500hp..so there really isnt any need to change it ya know?
12-31-2006, 09:59 AM #7
is there anyone on ls1.com that ports TB's? i would like to get mine ported but just do not have the time
12-31-2006, 02:07 PM #8
mine took me 2and a half hours at my shop on my day off, just get a walmart griner set for 50 bucks and a sandpaper kit from the parts store and remove all sharp edges and the big lip right before the butterfly, sand it with 400 grit then 1000 then 2000 for a nice finish, mine turned out great... take your time
12-31-2006, 03:07 PM #9King 0f n00bz
- Jan 2006
really all you need to do is polish it up. try not to mess with the tb too much, you'll be asking for trouble. like said before it can handle 500 hp so really it doesnt need any help..unless your pushing more then 500crank. but there is a tutorial on installuniversity.com if you must fittle with it.
01-01-2007, 06:37 PM #10
I did mine and so did a couple other people around here. Just takes a day and some patience. Oh yeah and a dremel. basically there is just a bump in there before you get to the blade, just grind that our of there and wetsand the rest of the inside and then polish is up nicely. you will gain minimal hp though..
01-01-2007, 08:07 PM #11
Throttle body question
By 01A4Z28 in forum External EngineReplies: 6Last Post: 02-27-2011, 09:03 PM -
Throttle Body Question
By TransAm11973 in forum General HelpReplies: 8Last Post: 01-19-2009, 07:52 AM -
Question: Throttle body question
By screamindemon in forum External EngineReplies: 4Last Post: 01-17-2009, 04:16 PM -
By blue02Z in forum External EngineReplies: 1Last Post: 05-28-2006, 05:01 PM -
Throttle Body question
By SSzoe in forum External EngineReplies: 3Last Post: 02-21-2006, 07:51 AM
