    Dec 2008
    south dakota
    Throttle body question
    on a 1999 trans am, if i got a 85mm throttle body would i need to get a cam or not. what is a good intake manifold that would go with a 85mm throttle body as well? also is it possible to have to big of throttle body for the stock ls1 cam?
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    no it isn't... if you want to get an 85mm tb you might as well get a 90mm or 92mm and if you do that you have to match it up to an intake such as the FAST which is $$$ and if you're going to go through that much trouble you might aswell do heads and cam otherwise you're spending $$$ money on a intake/tb and not seeing very many gains for it.
    What I would recommend for you is just getting your stock TB ported/polished thats MORE then sufficient for a stock cubed ls1 unless it has h/c
    since you have a 99 invest in the LS6 intake match that with your p&p stock tb and you'll be set for just about anything.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Unless your pushing upwards of 500hp at the wheels keep your stock throtle body. You can have your stocker ported but i would wait until you decide to get it tunned.
    J
    Dec 2008
    south dakota
    so if i get an ls6 intake manifold my stock p&p throttle body will fit right on it right??? also the ls6 intake does not have egr or am i mistaken?? thanks for the help
    Retired Outlaw Sum Bitch
    Quote Originally Posted by screamindemon View Post
    Yeah it will fit...and no it doesn't have EGR...if you need to keep your EGR functional you can get a conversion from Lingenfelter...
    http://www.lingenfelter.com/document...ctionsv1.0.pdf
    Also I agree....if your under 500RWHP your stocker is good to go.
  1. Throttle body question
    By 01A4Z28 in forum External Engine
    Last Post: 02-27-2011, 10:03 PM
  2. Throttle Body Question
    By TransAm11973 in forum General Help
    Last Post: 01-19-2009, 08:52 AM
  3. throttle body question
    By camaro_five0 in forum External Engine
    Last Post: 01-01-2007, 09:07 PM
  4. Throttle body question
    By blue02Z in forum External Engine
    Last Post: 05-28-2006, 06:01 PM
  5. Throttle Body question
    By SSzoe in forum External Engine
    Last Post: 02-21-2006, 08:51 AM
