12-07-2006, 08:15 PM #1
Replacing turn signal marker lamp
Oh man, did i have fun replacing that sunuvabitch! Took awhile to realize I had to reach into the bumper to turn the socket and replace the light. After fighting to put the bulb in I realize that the bulb is orange whereas the other side is white...GRRR
Any tips to replacing the bulb?
12-08-2006, 03:02 AM #2
I'm assuming you're talking about the front turn signals. When you said you reached into the bumber, did you go through one of the air intakes? Did you know there is a flap on the bottom held up by two bolts that gives you access?
Tip: If you find that you're having to replace a bulb after it rains. I would recommend pulling off the housing and sealing it as well as placing some bulb grease in the socket. Since I've done this to my front left. I haven't had any problems.
12-08-2006, 03:32 AM #3
Before i added dielectric grease to my sockets I was changing bulbs all the time. If you reach your hand through the air intake you can reach the socket on the bottom of the housing. Turn it counter clockwise about 1 quarter of a turn, and it will pull out. It should have enough wire on it to pull out through the air intake to change the bulb....
12-08-2006, 11:27 AM #4
I did go through the air intake but I didn't have enough wire to pull it out. It felt tight when I pulled it so I didn't want to tear anything by pulling it harder so I changed the bulb with one hand inside the intake. I'm going to replace the other one so I have the same color on both sides as well as seal it with die electrice grease. Thanks for the tips!
12-08-2006, 08:03 PM #5
12-09-2006, 12:54 PM #6
I would rather not have to get out tools for a job i can do by sticking my hand through a hole in 1/8 the time.
01-24-2007, 10:30 AM #7Member
- Virgina
Black- 98 Trans Am
01-24-2007, 10:40 AM #8
Its not that hard to get into, especially when u pop the headlight.
Turn Signal/DRL Socket and Lamp venting
By Whamhammer in forum Firebird / WS6Replies: 1Last Post: 02-28-2014, 04:01 PM -
Driver side turn signal lamp on when lights are off????
By BigLT42 in forum General HelpReplies: 2Last Post: 02-26-2012, 08:37 PM -
Help: replacing turn signal bulb in a 97 camaro RS
By 01SOMSS! in forum Camaro / SSReplies: 6Last Post: 11-09-2008, 07:43 PM -
By 01SOMSS! in forum Appearance SectionReplies: 2Last Post: 11-07-2008, 06:32 AM -
Replacing Turn signal bulb
By LA Girl99 in forum General HelpReplies: 10Last Post: 08-12-2005, 08:02 AM
