Results 1 to 3 of 3
11-06-2008, 07:59 PM #1
replacing turn signal bulb in a 97 camaro RS
whats the easiest way to replace a turn signal bulb in a 93-97 camaro? I know the 98 and newer cars are easy as hell,but the older cars don't have a gap behind the headlights to fit your hand in there. i was thinking maybe removing the fender wall. what do you guys do?thanks!
11-07-2008, 02:35 AM #2Impounded
- Oct 2007
- Beaver Dam KY
edit... google !! but i was right!!
How do you get to the bulb to change out the right front turn signal on a 1997 Camaro RS is it the same procedure as on a 1999?
Answer
First you have to elevate the car so that you can safely get under the front of it. Right in front of the right front tire you will notice several 10mm bolts holding up the plastic under panning. Remove those bolts, then drop down the plastic under panning and this will expose the back of the right front turn signal. Just reach up and twist out the bulb receptical to remove it and replace the old bulb with a 3157NALL bulb. It only takes about 10 minutes once you get the front of the car safely elevated enough to get under it.Last edited by JoshieDoom; 11-07-2008 at 02:39 AM.
11-07-2008, 06:32 AM #3
so its the same procedure as the 98 and ups?
changing drl/turn signal bulb
By buzzkill in forum Camaro / SSReplies: 20Last Post: 10-26-2009, 07:27 PM -
Help: replacing turn signal bulb in a 97 camaro RS
By 01SOMSS! in forum Camaro / SSReplies: 6Last Post: 11-09-2008, 07:43 PM -
turn signal/drl bulb issue
By 1MileCrash in forum General HelpReplies: 11Last Post: 11-06-2008, 05:44 PM -
Replacing L front turn signal bulb
By Danger731 in forum General HelpReplies: 6Last Post: 10-19-2005, 11:25 AM -
Replacing Turn signal bulb
By LA Girl99 in forum General HelpReplies: 10Last Post: 08-12-2005, 08:02 AM
