    Aug 2006
    Oceanside,CA
    SOM
    01 Camaro SS
    replacing turn signal bulb in a 97 camaro RS
    whats the easiest way to replace a turn signal bulb in a 93-97 camaro? I know the 98 and newer cars are easy as hell,but the older cars don't have a gap behind the headlights to fit your hand in there. i was thinking maybe removing the fender wall. what do you guys do?thanks!
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    First you have to elevate the car so that you can safely get under the front of it. Right in front of the right front tire you will notice several 10mm bolts holding up the plastic under panning. Remove those bolts, then drop down the plastic under panning and this will expose the back of the right front turn signal. Just reach up and twist out the bulb receptical to remove it and replace the old bulb with a 3157NALL bulb. It only takes about 10 minutes once you get the front of the car safely elevated enough to get under it.
    Aug 2006
    Oceanside,CA
    SOM
    01 Camaro SS
    thnx,but i think this works only on 98 and up,not lt1's.
    Member km346's Avatar
    Nov 2008
    masssaaechuuuseettes
    1998 hardtop SS
    Quote Originally Posted by 01SOMSS! View Post
    Ive done it on both my LS1 and a buddies 97 LT1 car and they have the same "trap door" just take the two 10mm bolts out and you should be able to reach right up there.
    Beaver Dam KY
    79 T/A -91 Firebird
    Yep. Checked out my friends 94 today...same on the birds
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    yeah, theres a little triangle shaped piece, i think it has some louvers on it, taking the fender well out will work too.
    Aug 2006
    Oceanside,CA
    SOM
    01 Camaro SS
    done. thanks.
  1. changing drl/turn signal bulb
    By buzzkill in forum Camaro / SS
    Last Post: 10-26-2009, 07:27 PM
  2. replacing turn signal bulb in a 97 camaro RS
    By 01SOMSS! in forum Appearance Section
    Last Post: 11-07-2008, 06:32 AM
  3. turn signal/drl bulb issue
    By 1MileCrash in forum General Help
    Last Post: 11-06-2008, 05:44 PM
  4. Replacing L front turn signal bulb
    By Danger731 in forum General Help
    Last Post: 10-19-2005, 11:25 AM
  5. Replacing Turn signal bulb
    By LA Girl99 in forum General Help
    Last Post: 08-12-2005, 08:02 AM
