    Feb 2006
    Western North Carolina
    97 Z28
    Angry Help. I have not heat at startup?
    My car has gotten to where in the mornings(35 degrees) when I heat the car up for 15 mins,the heat is only warm coming out of the vents. After the car has run for 30-40 mins it is really hot. I have had the radiator flushed,thermostat replaced and the whole heater hose/line assembly replaced because it needed it. I have been told that the only thing left to replace would be the heater core. What I don't understand is,if the car doesn't get warm in the morning when first started,then gets really hot after awhile,how can it be the heater core? Seems to me that I wouldn't get any heat at all??
    97 Camaro Z28
    # 1846 mahoney1's Avatar
    Malden Ma.
    CETA Yellow
    2002 WS6 CETA
    You dont have a problem its called getting cold outside, so it takes longer to heat up!
    Aug 2006
    Missouri
    94 Camaro Z28
    Yeah, it will take awhile for the car to heat up. That completely normal, for any vehicle. The car is heated from the engine, so when the engine is cold, the air will be cold. The heater core extracts the heat from the engine coolant, so when the coolant is cold, the air will be cold. That's why when your engine is overheating in the summer, you can help cool it off by turning on the heater.
    Feb 2006
    97 Z28
    I don't think that's the problem. Last year after 10 mins the air was hot.Now it's warm.
    Malden Ma.
    CETA Yellow
    2002 WS6 CETA
    then go to a garage and have them look at it!
    Feb 2006
    2002 WS6
    Could be a blocked core, try giving just it a flush.
    Feb 2006
    97 Z28
    My first post says what I have had done already. I have had the system flushed twice to no avail. I may just go ahead and replace the core,everything else has been replaced.
    Aug 2006
    Missouri
    94 Camaro Z28
    What type of thermostat are you running? And make sure you have a proper mix of water and coolant.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Quote Originally Posted by Red97LT1 View Post
    97 Camaro Z28
    While 30 to 40 mintues seems too long... i assure you your car is ok. Everything sounds fine. Like said above.... it takes time to warm up.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    The bigger the engine the longer it will take, a 4cyl or 6cyl will make heat quicker than a V8. Make sure you don't have a cold thermostat either for that weather. 180 or 190 is cold enough.
    Feb 2006
    97 Z28
    Thanks for the replies. I replaced the Heater core yesterday and this morning everything seemed fine.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Checking the flow of the core is easy, hook a hose to the inlet and see what volume comes out of the outlet. There is a TB about LT1 cores getting clogged and a specific flush method. I am betting your core is clogged. When the engine begins to warm up in the morning feel the two hoses, if one is hot and one is cold it is the flow through the core.
  1. First startup vid after cam swap
    By Ryans99LS1 in forum Multimedia Section
    Last Post: 08-21-2009, 11:17 AM
  2. winter startup
    By charlesss in forum General Help
    Last Post: 02-03-2007, 08:15 AM
  3. loud ticking on startup
    By absolutetraction in forum Internal Engine
    Last Post: 10-27-2006, 12:01 PM
  4. Howling at startup?
    By MarkuzLS1 in forum External Engine
    Last Post: 06-30-2006, 08:45 AM
  5. Startup Noise
    By ss~zoso~ss in forum Camaro / SS
    Last Post: 12-08-2005, 01:08 PM
