Thread: winter startup
02-02-2007, 12:41 PM #1Member
- Aug 2006
- canada
bright rally red- 2002 ss 35th
winter startup
Iv had the 02 camaro ss in storage since september. I start it up once a month does the freezing temps do any harm when starting the car or should I just leave it alone.
02-02-2007, 05:43 PM #2Junior Member
- Oct 2005
- ohio
I start mine up twice a month at least in the winter even though my garage is heated and drive it around the block if weather permits. Let it run till the thermostat opens and blows heat out the heater. Move it back and forth at least. Letting a car sit all winter is not that great for it.
02-02-2007, 11:46 PM #3
I would recommend that you use a battery tender to keep your battery charged. It's a good thing to at least start you car once every couple of weeks (better if you can take it for a drive if possible) - it keeps the oil circulating in the engine so the moving parts have a film of lubricant on them. Try not to rev a cold engine: let the oil circulate for a bit through the engine until you start feeling some heat. Also, turn on the A/C (with the temperature knob cranked up) and let it run for a bit. There's compressor oil in the Freon which keeps the A/C compressor lubricated, and circulating the Freon helps keep the A/C system seals and hoses from drying out. As the saying goes, "Use it or lose it" is very true...
02-03-2007, 02:07 AM #4
02-03-2007, 08:15 AM #5Member
- Aug 2006
- canada
good points to remember thanks.
First startup vid after cam swap
By Ryans99LS1 in forum Multimedia SectionReplies: 23Last Post: 08-21-2009, 11:17 AM -
weird noise on startup?
By jmatt07 in forum General HelpReplies: 12Last Post: 09-25-2008, 12:47 PM -
Help. I have not heat at startup?
By Red97LT1 in forum External EngineReplies: 11Last Post: 11-19-2006, 03:29 PM -
Howling at startup?
By MarkuzLS1 in forum External EngineReplies: 11Last Post: 06-30-2006, 08:45 AM -
Startup Noise
By ss~zoso~ss in forum Camaro / SSReplies: 8Last Post: 12-08-2005, 01:08 PM
