Results 1 to 10 of 10
Thread: loud ticking on startup
10-18-2006, 05:46 PM #1Junior Member
- Sep 2005
- missouri
black- 98 Z28
I searched and couldn't find anything exactly like my situation. My 98 Z28 has a loud tick and i mean loud, when i first start it up after it has been sitting for a couple of hours. After about 3 minutes it is fine and sounds normal. The ticking is definetely louder now that it is cold outside. My buddy says it could be the pushrods, thinking i bent one. I have an automatic though, can u bend pushrods in an automatic? Thanks guys
10-18-2006, 06:28 PM #2
if it goes away i'd say its just valve noise and once they get lubed up *takes longer when its colder due to thicker viscosity of oil* the noise stops
10-23-2006, 02:27 PM #3Member
- Oct 2005
- RI
Mag Red- 2002 Vette
Sounds like the lifters are losing oil, is it stock, how many miles, what oil and is it only when cold?
10-23-2006, 02:41 PM #4
10-24-2006, 09:44 PM #5Junior Member
- Feb 2006
- New Jersey
Sebring Silver- 1998 Camaro SS
I have noticed the same thing with mine also. When I first bought the car new I took it in because of a slight ticking and they checked it and told me it was normal for an aluminum engine to transmit some valvetrain noises. The car is now over 8 years old and I believe the noise is louder. Not sure if I am hearing a noise from the accessories or lifter chatter. The car is a 98 SS with 30,000 miles and it sits quite a bit in the garage. The lifters may just be bleeding down but not really sure. The valvetrain is completely stock and it runs awesome.
10-26-2006, 05:57 PM #6
What is dealeo with that. Stock lifter prone to what ever this is? Is there a fix or just a replace. I myself have valve noise and it is driving me up the wall.. my car sounds like a sewing machine. If i didn't have the loudmouth 2 exhaust i wouldn't even drive the car till i got it fixed. It's embarrassing.
I need to locate what this sound is emitting from and get rid of it. I don't care if it's "just valve noise". I want my engine to purrr not stitch a bedspread. If it gets any worse i will get custom plates that says "Singer"
10-26-2006, 07:16 PM #7Senior Member
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
12.6 at 112
10-27-2006, 03:50 AM #8
10-27-2006, 11:52 AM #9Member
- Sep 2006
- San Dieg-izzle
black/red- 2003 SVT Cobra/1999 T/A
my vote goes towards piston slap.
10-27-2006, 12:01 PM #10
Ye I thought that too but. Rob at Overkill and others have said it sounded like vavle train noise.
Note: I di a oil change yesterday to 10w30 Redline engine oil and it has quieted down.
First startup vid after cam swap
By Ryans99LS1 in forum Multimedia SectionReplies: 23Last Post: 08-21-2009, 11:17 AM -
Loud ticking noise after cam install
By gunguyWS6 in forum Internal EngineReplies: 8Last Post: 11-01-2007, 04:05 PM -
winter startup
By charlesss in forum General HelpReplies: 4Last Post: 02-03-2007, 08:15 AM -
Howling at startup?
By MarkuzLS1 in forum External EngineReplies: 11Last Post: 06-30-2006, 08:45 AM -
Loud Mouth or Loud MouthII
By 94camm in forum External EngineReplies: 6Last Post: 10-14-2005, 07:10 PM
that or a really bad case of piston
