Results 1 to 1 of 1
Thread: Engine running rough...need help
10-25-2006, 10:37 AM #1Junior Member
- Sep 2006
- arkansas
white- '98 Z28
OK... I had a reputable shop do an A4 to T56 swap on my 98 Z... everything works fine... except the gears whine (problem soon to be solved)... I had a reputable programmer do the work on the computer... Now the car runs much rougher at idle but even more so when you are sitting still and rev to about 2,000 RPM... it's pretty rough. I had a high performance tune put in. I'm running stock manifolds.
What do I do... change the plugs, check the balance on the flywheel, or is it the exhaust that is causing my problem... the car was never this rough before the swap... any advice would be appreciated.
Question: Lq4 running rough
By Ripper3494 in forum General HelpReplies: 17Last Post: 10-25-2011, 03:01 AM -
help- car's running rough
By Ramairgod84 in forum General HelpReplies: 2Last Post: 08-14-2010, 06:36 AM -
Engine running Rough
By andyramsaran in forum GTOReplies: 6Last Post: 07-25-2010, 08:06 AM -
ls1 running rough
By ls1_02 in forum General HelpReplies: 0Last Post: 01-04-2008, 08:43 PM -
engine running rough
By 8secpumpgas in forum General HelpReplies: 1Last Post: 05-14-2007, 01:10 PM
