    Mar 2010
    Oak Lawn/ Chicagoland
    Yellow
    2004 GTO
    Engine running Rough
    Well Guys i found a problem that is common with GTO's causing the engine to run rough with no miss fire and lean HO2 sensor bank 2 sensor 2 the wire's get cut and short out peel back the loom and inspect wring i found on my car one brown and one tan was torching together i have seen a lot of guys said that there engine run rough
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    You mean under the fuel rail covers? The pic you posted is a red x.
    Universal Pisser Offer Fester801's Avatar
    Oct 2009
    Grapevine, TX
    Torrid Red
    05 GTO M6
    Good info... DO NOT be afraid of punctuation in your posts. It makes them much easier to read. And yes, if you tried to attach a pic, it did not come through.
    Mar 2010
    Yellow
    2004 GTO
    09 G8 GT
    What are we looking @ here? Are your O2 sensor wires actually cut???
    Mar 2010
    Yellow
    2004 GTO
    yes they get cut because off the angle it's at on bank 2 sensor 2
    North Jersey
    2004 GTO M6
    Either solder the wires back together and use heat shrink wrap, or buy replacements.
  1. Question: Lq4 running rough
    By Ripper3494 in forum General Help
    Last Post: 10-25-2011, 03:01 AM
  2. help- car's running rough
    By Ramairgod84 in forum General Help
    Last Post: 08-14-2010, 06:36 AM
  3. ls1 running rough
    By ls1_02 in forum General Help
    Last Post: 01-04-2008, 08:43 PM
  4. engine running rough
    By 8secpumpgas in forum General Help
    Last Post: 05-14-2007, 01:10 PM
  5. Engine running rough...need help
    By z28luvva in forum General Help
    Last Post: 10-25-2006, 10:37 AM
