Results 1 to 18 of 18
Thread: Lq4 running rough
10-22-2011, 06:22 PM #1Junior Member
- Oct 2011
- Warrenville
Black and blue- 1994 wrangler
Lq4 running rough
I just finished installing a 2004 lq4 out of a silverado 2500hd into my wrangler. My issue is that it seems to run rough and not quite have the power most of the time. But every once in awhile for a second itll run perfect and extremely smooth... Just wondering what some of the experts over here think of it
Thanks in advance
10-22-2011, 09:57 PM #2
welcome to the site!
can you tell us more about it? is it a stock lq4? direct swap pcm, harness, and tune? are there any codes being set that you know of?Last edited by My00Z28; 10-22-2011 at 10:09 PM.
10-23-2011, 05:56 AM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Could be a number of issues - MAF, vacuum leak, fuel pressure, ect.. Check the easy stuff first to rule that out, then move on.
10-23-2011, 07:50 AM #4Junior Member
- Oct 2011
- Warrenville
10-23-2011, 07:56 AM #5Junior Member
- Oct 2011
- Warrenville
i just fixed a vacuum leak yesterday. one thing i have been noticing when i hit the throttle it creates a really loud sucking sound from the intake. ive heard that only once before and it was on a friend who we swapped an l98 into his s10, what caused it was an improper tune. as for fuel the lq4 has a return less system and the jeep has a return line as of right now its ziptied off to the side, could that potentially be an issue? ive been trying to find what the lq4 requires for fuel pressure but im failing to find it... i know the jeeps system puts out approx 55 psi
10-23-2011, 10:43 AM #6Junior Member
- Oct 2011
- Warrenville
I just retested my fuel pressure, I was, wrong my system sits at 65psi
10-23-2011, 10:46 AM #7
im not sure off the top of my head but 65psi should be more than enough to run that motor! whats the pressure drop to when you start the engine?
10-23-2011, 01:41 PM #8Junior Member
- Oct 2011
- Warrenville
The pressure doesnt hardly drop at all, it comes down maybe 1 or 2 psi
Originally Posted by My00Z28:2712541
10-23-2011, 03:39 PM #9
10-23-2011, 05:32 PM #10Junior Member
- Oct 2011
- Warrenville
Checked the maf and it was clear, couldn't find any more vacuum leaks. Is it possible that my air filter is limiting how much air my engine can draw in? Its the middle size cone filter from autozone... Just a thought
Honestly it feels like a cylinder isnt firing but that would throw an error code faster than hell
10-23-2011, 05:49 PM #11None Shall Pass
- Jan 2010
It's possible you may be restricting too much air. You could remove the filter temporarily to see if things don't improve. I would expect a code from most things I'm thinking of, but that doesn't always mean you'll get one. Also, just because the MAF looks clear, doesn't mean it's reading properly. Pick up a can of CRC cleaner and clean it good. Follow the instructions on the can. If that doesn't improve anything, you could spray some starting fluid around to check for vacuum leaks.
10-23-2011, 06:11 PM #12Junior Member
- Oct 2011
- Warrenville
Ill grab some cleaner tomorrow, and what do you mean spray starting fluid to check for vacuum leaks. Sorry if its a dumb question but I've never heard of doing that
Originally Posted by Knight:2712676
10-23-2011, 06:16 PM #13None Shall Pass
- Jan 2010
Spray a little starting fluid around the vacuum hoses and intake. If the idle raises, you have a vacuum leak. I'd do it with the filter installed though, so as to not get a false idle rise. It's an old trick.
And there's no dumb questions here. We're all learning, some of us are just a little ahead of others
10-23-2011, 06:23 PM #14Junior Member
- Oct 2011
- Warrenville
Lol thanks, I just did a quick run with no air filter and saw no significant difference, will clean the maf and look for vacuum leaks tomorrow. the engine puts out a ton of power for the jeep but I have a silverado with the same engine and I know it should be running better...
10-24-2011, 07:30 AM #15Junior Member
- Oct 2011
- Warrenville
Did some reading about maf sensors today. one article said to unplug it and run it like that. It says the pcm will create a value for the sensor and if it runs better without it thats the problem. If it runs worse then the issue is somewhere else. I figure ill try that first after school and if thats not it ill look for vacuum leaks. If its not that then I'm stumped
10-24-2011, 06:21 PM #16Junior Member
- Oct 2011
- Warrenville
I feel dumb, it was a loose plug wire
10-25-2011, 02:52 AM #17
Lol been there done that
10-25-2011, 03:01 AM #18None Shall Pass
- Jan 2010
At least it was a simple fix.
Question: running rough
By 90ARAPAJ in forum Firebird / WS6Replies: 3Last Post: 06-21-2011, 11:47 AM -
help- car's running rough
By Ramairgod84 in forum General HelpReplies: 2Last Post: 08-14-2010, 06:36 AM -
ls1 running rough
By ls1_02 in forum General HelpReplies: 0Last Post: 01-04-2008, 08:43 PM -
94 Z28 running rough, any help?
By 1st TA in forum LT1Replies: 4Last Post: 06-17-2007, 05:26 AM -
engine running rough
By 8secpumpgas in forum General HelpReplies: 1Last Post: 05-14-2007, 01:10 PM
