    Junior Member kosovobandit's Avatar
    beaumont
    pewter
    1999 corvette
    tire size and active handling system
    I am thinking of getting the C6 Z06 wheels in the 17x9.5 in front and 18x10.5 in the back. I have 17x8.5 in front and 18x9.5 in back. Will the change affect my active handling system. They are going on a 99 vette. thankyou for the help.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by kosovobandit View Post
    i think you will be alright.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    while widening the wheel will shorten the tire, assuming the same tire being used, you are doing it equally on the front and rear. so, i see no issues at all.
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    Here's my setup:
    Motorsport Z06 17x9.5 front and 18x10.5 rear
    Nitto 275/40ZR-17 front and 285/35ZR-18 rear
    Have had no problems of any kind. Now, if your car is lowered, or you plan on lowering it (like it did), this will complicate clearance a bit, but its correctable.
  1. tire size questions to the tire gurus!
    By vonskeezy28 in forum Wheels and Tires
    Last Post: 04-30-2011, 09:01 AM
  2. Tips for adjusting handling & handling bias
    By Intrepidman in forum Suspension and Handling
    Last Post: 05-22-2010, 04:34 AM
  3. Help: C6 Corvette ABS and Active handling faults @90mph
    By BigDz in forum General Help
    Last Post: 09-02-2009, 01:52 PM
  4. Alignment Spec handling/tire wear
    Last Post: 05-04-2009, 06:22 PM
  5. What Tire Size?
    By schrysler in forum Wheels and Tires
    Last Post: 08-09-2007, 10:30 PM
