05-19-2010, 07:58 PM #1Member
- May 2008
- New Brunswick
Tips for adjusting handling & handling bias
I've been reading up on handling recently and I seem to be getting mixed information for various sources.
Wikipedia of course can't be taken as gospel but it does have quite a technical write up for anyone interested.
However it includes a chart of adjustments and thier effect, which I see being stated to the opposite in other writings.
I'm wondering if someone can difinitively chime in on weather Wiki has it right or backwards. (for example, it seems to state that In The Front > softer front shocks, a smaller sway bar, and lower tire pressure will help cure an understeer problem)
http://en.wikipedia.org/wiki/Car_handlingLast edited by Intrepidman; 05-19-2010 at 08:01 PM.
05-21-2010, 11:36 AM #2
i agree with intrepidman except, for front tire air pressure.. higher is better 35> 42 LBS ,to help less understeer... rkvette
05-21-2010, 11:45 AM #3
Let me start off by saying I know very little about handling.
But it seems to me if you have understeer you are pushing the front end. So LESS tire pressure would give you more grip and less push.
05-21-2010, 12:25 PM #4
05-21-2010, 12:35 PM #5O U 8 1 2
- Nov 1999
- over here...
talk to our sponsor UMI... let them know what goals you have as far as handling and they'll tell you what to do and what to get to make it happen...
05-22-2010, 04:34 AM #6
having won a-stock/ auto-crosses , in a 1967 corvette/conv.427 big block, was not easy... vette really plowed/understeer.. here are some tips that worked for me. larger rear bar went from 9/16 to 7/8 a lot heavier..lots of neg. camber in fronts like -2 deg.,0 toe, lots of pos.caster...rear some neg.camber 1/2 or so..shaved /bald/soft tires all around.. fronts about 40lbs rears about 35 lbs.. drive around in circles to warm them, just before doing the course...had the vette set up towards little oversteer, fastest way through the cones !!! rkvette
Question: handling
By jjjr311 in forum Suspension and HandlingReplies: 17Last Post: 01-21-2010, 06:39 AM -
01 Z28 Handling
By karpetcm in forum Suspension and HandlingReplies: 1Last Post: 07-25-2009, 09:51 PM -
Handling
By transamterror in forum Firebird / WS6Replies: 52Last Post: 07-07-2007, 01:52 PM -
handling?
By joker in forum Firebird / WS6Replies: 20Last Post: 12-20-2006, 05:52 AM -
Would like better handling
By Black Dragon in forum Suspension and HandlingReplies: 13Last Post: 10-19-2005, 08:05 AM
