Results 1 to 18 of 18
Thread: handling
    Junior Member jjjr311's Avatar
    nj
    1998 z28
    handling
    how can i get my 98 z28 to handle better. Should i start with lowereing it....???? or tower bar and subrame connectors....?????? what brand to buy...???
    Tires, shocks, sub frame connectors, rear lower control arms, and sway bars would be a good start. Strut tower brace is a waste of money.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Quality shocks will make the single biggest difference.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    nj
    1998 z28
    thanks for the input. my biggest concern is eliminating body roll. what shocks do you reccomend for street driving.
    new jersey
    navy blue metallic
    2000 trans am
    springs, shocks, and swaybars will have the greatest effects on overall handling.
    koni shocks are ideal but expensive. well worth it, but if you can't afford them then go with the SLP bilsteins. i have them and i'm happy, but i certainly wouldn't go with anything cheaper. to eliminate roll, the biggest things are going to be springs and swaybars. i would recommend 35/21 or 35/22 swaybars (i have 35/21 and love it) and strano springs (generally considered the best lowering springs out there).
    do you go to WPU?
    nj
    1998 z28
    thanks for the info. whats wpu?
    new jersey
    navy blue metallic
    2000 trans am
    a school haha nevermind
    nj
    1998 z28
    which konis should i get?
    NC
    SOM
    1998 T.A.
    Koni single adjustable. I have the 4/4's but I never change my rear setting now that I have them where I want them so wish I should have saved the $100 and gone 4/3. I have Strano springs and bars too and UMI rod ended PHB and highly recommend this setup. A watts link would help too but I have higher priorities like a new rear with my car right now.
    Member blk99ws6ta's Avatar
    Palestine,Il
    1999 WS6 Ram Air Trans-Am
    You will see the most difference with koni shocks alone. I have 4/3 koni shocks with strano springs. It's like night and day difference from your old stock shocks and koni. They are the best all around shock to buy.
    NC
    SOM
    1998 T.A.
    ^^^^^^^ I agree with this statement. 35/22 bars are second and properly balanced springs third. You have to be careful with springs because there are many choices but very few that got it right.....
    nj
    1998 z28
    thanks for all the good info!!!
    Do they make american racing heades for 98 z28?
    Brookville, PA
    2001 Z28
    Quote Originally Posted by SOMbitch View Post
    But you are likely in a "setting" that the 4/3's might not have been able to offer. Not just about easier adjustment, the 4/4's allow you to set the shocks anywhere you like, not only within certain detent positions which is how the 4/3's work......
    NC
    SOM
    1998 T.A.
    Quote Originally Posted by Sam Strano View Post
    You are right Sam but since I don't competively race I probabaly don't need the fine tunability of the 4/4's.This is no knock on your setup in anyway. After 3 4th gens with different setups yours is hands down the best.
    I am really wanting a watts link to add to it but just gotta do some stuff like a rear to keep me on the road first.....
    Brookville, PA
    2001 Z28
    Let's make this simple (and for the record, don't think you were knocking the setup ).
    Are you full soft? Are you about 1/2 turn up from soft? Are you about 1 full turn up from soft, or are you full stiff. If you are using some setting other than those, you are in a place not accessible to the rear shocks from a set of 4/3's. Which means you can only get to where you might be (don't know where you are set actually) by having 4/4's. fwiw.
    Sam Strano
    SCCA National Champion (x6)
    SCCA ProSolo Class Champion (x5)
    2009 SCCA ProSolo Overall Champion
    Owner--Strano Performance Parts
    814-849-3450
    NC
    SOM
    1998 T.A.
    I am one turn from full soft on the rear and and two turns from full hard on the front normally.
    I recently made a 1200 mile roud trip to Ohio and softened the front up two turns because the road is so bad in parts of W.Va and KY. It made a noticeable difference and made the trip much more enjoyable..... I felt I was literally killing the car my first trip. I do love the flexibility of these shocks. That was the only time I changed them though after I found the sweet handling spot.
    Brookville, PA
    2001 Z28
    In hindsight, because of your chosen setting in the rear, you could have gotten that with 4/3's. But it would have taken more time to "get there". Also, as they say, hindsight is 20/20! You couldn't have known that the setting you settled on was also one available to you in 4/3's.
    NC
    SOM
    1998 T.A.
    Live and learn........ Thanks!
  1. Tips for adjusting handling & handling bias
    By Intrepidman in forum Suspension and Handling
    Last Post: 05-22-2010, 04:34 AM
  2. 01 Z28 Handling
    By karpetcm in forum Suspension and Handling
    Last Post: 07-25-2009, 09:51 PM
  3. Help: Not Handling Right
    By jpn8801 in forum Suspension and Handling
    Last Post: 02-03-2009, 09:12 PM
  4. Handling
    By c5z28 in forum Suspension and Handling
    Last Post: 12-02-2008, 12:19 PM
  5. handling?
    By joker in forum Firebird / WS6
    Last Post: 12-20-2006, 05:52 AM
