Thread: Not Handling Right
02-03-2009, 05:06 PM #1
Not Handling Right
I Have the same re-occuring problem, whenever I am driving & turning to the right I get a whirring sound, Whir,Whir,Whir,Whir,Whir it seems like it whir's whith the turning of the tire... Now, this happens ONLY when I turn to the right while driving, left or straight is fine. While this happens I feel the vibration of this whirring on the driverside floorboard. Now I am thinking either it's my upper U-Joint, 1 or both front rotors?? (since all of them are warped REALLY bad) I am Stumped. I can't think of any other way to explain it? Has anyone had this problem?? Suggestions?
Thanks
02-03-2009, 05:19 PM #2
Could be a couple things. Its not a ball joint, they don't make the type of sound you are describing.
Usually warped rotors will not make that sound, either. They will just cause a pulsation in the steering wheel when you hit the brakes.
I'm betting its a wheel bearing. When a hub assembly goes bad, they often cause a vibration in the steering wheel while turning, and if they are really bad, they can make noises like you have described.
Pull your wheel off, remove your caliper bracket and rotor, and spin the hbb assembly. Listen for any grinding sounds and feel how much resistance it has. It should spin smoothly and quietly, if not, it needs to be replaced.
02-03-2009, 05:38 PM #3
Thanks for the reply
The wheel bearing might just be the culprit- I need to pull it apart & see, i have 71,xxx miles on the car, usually they dont go out that quick do they?
02-03-2009, 05:40 PM #4Impounded
- Oct 2007
- Beaver Dam KY
02-03-2009, 06:33 PM #5
02-03-2009, 09:12 PM #6Crazy Canuck !
- Jun 2002
- Montreal, CANADA
check the black plastic of inner fender in front of the driver side front tire... it might be out of place... I had that once... and all I needed to do was put it in its place tucked-in behind the front fender (I'm talking of the plastic piece right in front of the tire)... should not be sticking out on the bottom... needs to be tucked inside the front fender. worth the double-check
Eugenio_SS
Tips for adjusting handling & handling bias
By Intrepidman in forum Suspension and HandlingReplies: 5Last Post: 05-22-2010, 04:34 AM -
Question: handling
By jjjr311 in forum Suspension and HandlingReplies: 17Last Post: 01-21-2010, 06:39 AM -
01 Z28 Handling
By karpetcm in forum Suspension and HandlingReplies: 1Last Post: 07-25-2009, 09:51 PM -
Handling
By c5z28 in forum Suspension and HandlingReplies: 0Last Post: 12-02-2008, 12:19 PM -
handling?
By joker in forum Firebird / WS6Replies: 20Last Post: 12-20-2006, 05:52 AM
