Thread: What Tire Size?
    LS1-TA schrysler's Avatar
    utah
    1998 Trans Am Vert
    What Tire Size?
    I have found a killer deal on some rims and am looking for some tires, question is what would be the best tire sizes for 18x9.5 in back and 18x8.5 in the front? The back is a no brainer for me either 275/35/18 or 295/35/18 but the front is where i am getting stuck, why do people do 245/40/18 in the front instead of keeping it 35?
    1998 Trans Am Vert, M6, Soon to be full of goodies......
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    it stays true to the stock diameter.
    utah
    1998 Trans Am Vert
    BUT THE FRONT AND THE BACK ARE 18's isnt the 35 or 40 the amount of side wall? I would think that it would look weird having two different size sidewalls on the same car.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by schrysler View Post
    sidewall height is determined by width. that 40 is a percentage number. 40% of 245mm gives you the sidewall height.
    i give tire sizes that are equivalent to factory tire diameter in the sticky above.
    http://www.ls1.com/forums/showthread.php?t=11359
    the 245/40-18 and the 275/35-18 have the same amount of sidewall. both on 18" wheels and both are 25.7" tall.
    Junior Member Talenuf's Avatar
    San Jose, Ca.
    1997 Trans Am WS6 vert
    Somewhere here is a chart of acceptable tire sizes for given wheel widths. Can somebody drop the link to that here? Thanks!
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    to calculate overall diameter... it's as follows:
    let's understand the #s.
    example : 275/40-17
    means
    275: width of tire = 275mm
    40: sidewall is 40% of 275mm = 275 x 0.40 = 110mm = 4.33" (note: 1" = 25.4mm)
    17: size of wheel = 17"
    Overall diameter = size of wheel + 2 sidewalls (the top and the bottom)
    OD = 17" + 2x4.33" = 25.66"
    so if we take 245/40-18
    sidewall: 245x0.4 = 98mm = 3.86"
    OD: 18" + 2x3.86" = 25.72"
    275/35-18
    sidewall: 275x0.35 = 96.25mm = 3.79"
    OD: 18" + 2x3.79" = 25.58"
    Hope this helps.
    Eugenio_SS
  1. Help: tire size ??
    By joetheta in forum Wheels and Tires
    Last Post: 08-07-2012, 07:06 PM
  2. tire size questions to the tire gurus!
    By vonskeezy28 in forum Wheels and Tires
    Last Post: 04-30-2011, 09:01 AM
  3. Question: tire size
    By o2 double s camaro in forum Wheels and Tires
    Last Post: 06-22-2009, 06:23 PM
  4. Question: What tire and size???
    By TACE02 in forum Wheels and Tires
    Last Post: 02-23-2008, 11:38 PM
  5. Tire size? all around
    By WS6ICK2K in forum Wheels and Tires
    Last Post: 02-12-2008, 10:02 AM
