Results 1 to 20 of 33
    Member WS6ICK2K's Avatar
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    Tire size? all around
    I wanted to keep my wheels and tires so I could still rotate. Which tire size should I run with 18s all the way around? 275-35-18?
    Member pewterzron's Avatar
    chicago
    NBM M6
    2000 SS
    That is the tire size i would use if I had 18's all the way around. But i guess you are not going to get directional tires????
    Quote Originally Posted by 00WS6BlueMetallic View Post
    295 35 18...
    Member MnLS1's Avatar
    Jan 2008
    SW Metro, MN
    1999 SS
    How wide are your 18's going to be? I'm running 275/35/18's on 18x10.5's and wish I had wider (it came with em on) so I'm gonna buy the 295's for the rear (the're bald), and then the front.
    chicago
    NBM M6
    2000 SS
    295 35 18...
    Depends on how wide da rims are. But 295 looks so much better.
    If you want 275s all around, the 275/35/18 would be a good sizing.
    Painted manta stripe
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    Rims are 9.5'' wide
    Rims are 9.5'' wide
    You want 275/35/18s all around then
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    Any good tire recomendations that are affordable? College budget kinda hard to spend 300$ + each tire.
    What can you afford to spend on all 4 tires, I can try to help you out if I know what you are looking to spend.
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    around $200 or less on each tire
    I was thinking about the Fuzion Zri but they dont make a 275-35-18
    Give me a few minutes, I will have something for you.
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    I appreciate the help
    http://www.discounttiredirect.com/di...pager.offset=0
    A list of 275/35/18s from Discount tire ^
    Free shipping from them.
    http://www.tirerack.com/tires/Compar...8&startIndex=0
    A list of 275/35/18s from Tirerack, not free shipping.
    The Nitto NT 555 Extreme would be a good choice from discount tire.
    If you could swing it, this is what I would recommend:
    http://www.discounttiredirect.com/di...37&rd=18&ar=35
    Best tires I have ever had. They run 239/tire from discount, but there is a $50 rebate from BFG, so you would be looking at ~$900 for all 4.
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    I love that aggresive tread on those BFGs I might have to invest. Do you think they would hold up long, because I know they have a low tread wear being soft compound.
    They have a 300 tread wear rating. That is pretty good really. On the 17" KDWs I got about 20k miles, they have a 300 tread wear rating as well. How long they hold up will depend a lot on your driving style as well, plus rotating them in a timely manner will help also.
    Those are the tires I currently have, and love the aggressive pattern as well, get lots of compliments on it.
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    I have had a set of BFG KDWs that lasted somewhere close to 3 years and around 30k miles. They still had tread on them when I just bought new tires, but they were starting to crack. They have also seen about 30 track passes 25 of which I have done a small burnout on. So I think they last fairly well good DD tire if you are in the warmer parts of the world.
  1. Help: tire size ??
    By joetheta in forum Wheels and Tires
    Last Post: 08-07-2012, 07:06 PM
  2. tire size questions to the tire gurus!
    By vonskeezy28 in forum Wheels and Tires
    Last Post: 04-30-2011, 09:01 AM
  3. Question: Tire size
    By izzhemp in forum Wheels and Tires
    Last Post: 10-07-2009, 05:45 PM
  4. Question: tire size
    By o2 double s camaro in forum Wheels and Tires
    Last Post: 06-22-2009, 06:23 PM
  5. Question: What tire and size???
    By TACE02 in forum Wheels and Tires
    Last Post: 02-23-2008, 11:38 PM
