    doylestown, Pa
    SILVER
    2004 CTS-V
    1.8 RATIO, SLP roller rockers
    I was wondering if I put SLP's 1.8 ratio rockers on my 98 Z28, with a proper tune, would I have any problem passing PA emissions tests?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I dont beleive so. But why put them on at all? Put your money into something else IMO.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    stock rockers are fine and for the price, invest in something else
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    As the others have said, stick with the stock rockers. I had gotten the 1.8 Crane roller rockers but then if you go to a more aggressive cam you have to start worrying about clearnance issues both with valve / pistons and valve covers. I went back to 1.7 and don't think 1.8's are worth it IMO.
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    no tune is needed if you go larger ratio rockers. while it can be a high doller per hp gain, for those that want more without changing a cam, it's a good direction to go.
    as far as cam selection goes, so long as your springs can handle it and you have proper piston to valve clearances, there won't be a problem.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    i had the slp 1.85s and sold them.
    save the money for a cam kit or headers.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    If you can pass the emissions test now, you'll still pass it with the new rockers.
    RI
    Mag Red
    2002 Vette
    Larger ratio rockers will increase the overlap triangle, is it a sniff test?
    Dec 2002
    n/w chicago
    Quote Originally Posted by vettenuts View Post
    still pass
  1. 1.7 LS1 Roller Rockers
    By ls1camino in forum Parts Wanted / Trade
    Last Post: 01-12-2009, 12:43 AM
  2. 1.85 ratio rockers & chrome moly pushrods for sale
    By 9t8z28 in forum Parts For Sale / Trade
    Last Post: 11-25-2008, 05:39 AM
  3. roller rockers
    By the_formula in forum Internal Engine
    Last Post: 05-09-2008, 09:11 PM
  4. Roller Rocker Ratio
    By WS6ICK in forum Internal Engine
    Last Post: 09-16-2006, 08:52 AM
  5. Roller Lifters and Aluminum Roller Rockers
    By MadSeason in forum Internal Engine
    Last Post: 03-14-2006, 02:23 PM
