Results 1 to 20 of 32
Thread: roller rockers
    conroe tx
    maple red metallic
    2000 firebird formula
    roller rockers
    i was thinking of swapping in some 1.7 rollers in my 2000 formula in place of the stock rockers..anyone know the hp gain with this? ...what else needs to be changed? springs ? lifters? pushrods?...
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    I thought 1.7 is stock size...
    conroe tx
    maple red metallic
    it may be...if so then 1.8?...anyway i still wanna get the rollers
    ASC #753
    not completely sure, didn't go that route... But if you get the 1.8s you change your overrall lift, higher (not sure just how much though, I don't know the math for figuring it up). I would say you wouldn't be doing wrong by upgrading the rest of the valvetrain while you are there, ie. springs and pushrods.
    Quick question: why not just install a cam and upgrade valvetrain? No need for upgrade of rockers then.
    Member tims02's Avatar
    Katy,TX
    Millenium Yellow
    2002 Coupe
    Mike,
    Yes 1.7's are stock rocker size. Depending on who's product you read they claim a 10-20 h.p increase with the swap to 1.8 or 1.85 rockers. Also, depending on what your looking to do with the engine the stock pushrods should work just fine but as far as the springs go high mileage vehicles should look into changing springs,retainers and locks anyways. Just holler at me and we can do that when you get them.
    conroe tx
    maple red metallic
    Quote Originally Posted by tims02 View Post
    Mike,
    i was wanting to get them when i get the headers....june sometime...getting a cam and heads for me will be a little hard to do due to budget..(as you may know tim) ...but i found the rockers for less than 200....so i thought maybe a cheap route for more hp.
    Katy,TX
    Millenium Yellow
    2002 Coupe
    yeah..H.P. is H.P. any way you can get it. What's the stock lift on the Firebirds cam?
    conroe tx
    maple red metallic
    not quite sure on that ....havnt gotten that far with the specs yet
    ASC #753
    1998 - 2000 Fbody
    202/210 int/exh @ 0.05" duration
    0.496" / 0.496" int/exh lift
    116 LSA
    http://www.smokemup.com/tech/ls1.php
    Katy,TX
    Millenium Yellow
    2002 Coupe
    Thanks Tace02. So with a set of 1.8 rockers your lift would be .525" / .525" and with a set of 1.85 rockers it would be .539" / .539"
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    be carefull with the springs...stock springs blow and can barely handle stock cam specs...i would deff upgrade the springs..when dealing with valvetrain..its better safe then sorry. the valvetrain is sorta like the spinal cord/nervous system of your engine...something goes wrong then so does everything else..be safe..upgrade your springs too.
    conroe tx
    maple red metallic
    can this be done without removing the heads??...if so then tim it looks like we got some work to do soon.
    Shepherd, Michigan
    98' trans am
    yes springs are on the top...no head removal is required..its actually really easy...remove the valve covers .. its easy.
    Katy,TX
    Millenium Yellow
    2002 Coupe
    Mike,
    Piece of cake buddy..Let me know when you're ready!!
    conroe tx
    maple red metallic
    i just wasnt sure if the springs were off that the valves wouldnt drop
    Katy,TX
    Millenium Yellow
    2002 Coupe
    They will if you don't blow air into the cylinder to keep them up in the head.
    conroe tx
    maple red metallic
    so i found a set of springs and rockers on ebay...what do ya think?
    http://cgi.ebay.com/ebaymotors/COMP-...spagenameZWD1V
    http://cgi.ebay.com/ebaymotors/Alumi...3286.m20.l1116
    Katy,TX
    Millenium Yellow
    2002 Coupe
    Thumbs up
    Mike,
    They look fine. They'll do everthing you need them to do. Gonna get 'em?
    conroe tx
    maple red metallic
    yea im gonna get em in june with the headers.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    dont waste youre money.
    i had 1.85 rockers in for a year then ditched them
    a few bolt ons, 379 rwhp
    11.96 @113.25
  1. prw roller rockers?
    By JROBINSON1016 in forum Internal Engine
    Last Post: 09-15-2013, 07:27 AM
  2. How To Buy Used Roller Rockers
    By Ed Blown Vert in forum General Help
    Last Post: 02-21-2013, 04:52 AM
  3. Roller Lifters and Aluminum Roller Rockers
    By MadSeason in forum Internal Engine
    Last Post: 03-14-2006, 02:23 PM
  4. anyone have the 1:8.5 roller rockers?......
    By 5 ltr. beater in forum Internal Engine
    Last Post: 03-06-2006, 06:12 AM
  5. roller rockers
    By lilicedout24 in forum Internal Engine
    Last Post: 12-15-2005, 08:17 AM
