    JMAC Racing WS6ICK's Avatar
    Kentucky
    2000 Trans Am WS6 LS6
    2006 GTO LS2
    Roller Rocker Ratio
    I am getting ready to install a LS6 kit on my 2000 Trans Am, LS1, WS6. I bought the stock GM heads and cam. My question is Summit sells a Harland Sharp roller rocker for LS1/LS6 and their ad says its a direct bolt on and will fit under stock valve covers for both engines. The stock ratio is 1.7:1 but I want to get the 1.8:1 ratio roller rockers. Will I have to worry about valve to piston clearance with the 1.8:1 ratio rockers? Do I need to change valve springs?
    Thanks
    Rochester Hills Michigan
    Ruby Red
    98 Camaro Z28 402 stroker
    no you should be just fine
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Talk to their technical service people and see what they say. Especially about pushrod length. They can help you.
    2002 Sunset Orange TransAm 6 spd.
    http://www.mustangmods.com/data/1327/dadsigpic2.jpg
    Ruby Red
    I would change the springs though
    Kentucky
    2006 GTO LS2
    If I decide to go with a bigger cam, what size should I get that will work with the stock LS6 heads, Pushrods and Lifters? The car has an A4. This car is not a daily driver but I do take it to the track on Friday nights and I would like to drive it on the HWY if I need to.
    Ruby Red
    If you go with a big cam I would go with stock size rockers, pushrods, and get a prc dual spring kit.
  1. Exploring Rocker-arm Ratio and Cam-phase Tuning - Project Pu
    Last Post: 08-08-2012, 08:30 PM
  2. High-Ratio Rocker Arms - Off Your Rocker
    Last Post: 08-19-2011, 02:50 PM
  3. 1.8 RATIO, SLP roller rockers
    By 9t8z28 in forum Internal Engine
    Last Post: 10-17-2006, 04:52 PM
  4. Crane Quick Lift 1.7 ratio Rocker Arm Kit
    By Camaro SS in forum Parts For Sale / Trade
    Last Post: 07-19-2006, 08:29 PM
  5. Question: Will Rocker Ratio Increase Fit
    By sgurski in forum Internal Engine
    Last Post: 08-15-2005, 09:59 PM
