08-10-2005, 05:39 AM #1sgurskiGuest
Question: Will Rocker Ratio Increase Fit
This question relates to a '99 C5 Corvette / LS1
I'm putting a set of ported AFR heads with comp 918 springs. At this time i'm not going to do a cam. I'd like to increase the rocker arm ratio from 1.6 to 1.7 (or 1.8 if it will fit). But that's the question will a 1.7 fit without interference?
thanks.
SG>
08-10-2005, 06:02 AM #2RipaGuest
Isn't the stock LS1 rocker ratio 1.7 ?
08-10-2005, 12:39 PM #3sgurskiGuest
Your right, the LS1 has a 1.7 RR. What about a 1.8 RR.
SG>
08-10-2005, 01:06 PM #4member since may 2000
- Dec 2002
- n/w chicago
my 1.85 cleared the valve covers.
a few bolt ons, 379 rwhp
11.96 @113.25
08-10-2005, 04:01 PM #5
I would stay with stock 1.7:1 and get a bigger cam
SLP 1.85 $450
New Cam around $400 and more power than just bigger rocker arms
lift is not what adds all the power duration, lift, LSA, ICL, overlap, ramp rate....
The big reason I so no to this is because when you do a cam in the future with the bigger Rockers and then a bigger cam with even more vavle lift you might have to take of the heads again to cut vavle reliefs
08-10-2005, 04:53 PM #6member since may 2000
- Dec 2002
- n/w chicago
Originally Posted by BerryWS6
i ditched my rocker arms because i cammed my car. i didnt wanna have to fly cut or anything.
the rocker arms gave me a 10 h.p bump.
08-11-2005, 06:01 AM #7sgurskiGuest
Cool thanks guys.
08-15-2005, 08:25 PM #8Junior Member
- Kentucky
S O M- 2002 Camaro SS
The answer to your question is that you can put higher ratio rockers on your car. I put Crane VHP 1.85 rockers on my 02 with absolutely no problems. Yes they are expensive compared to a cam and you probably need a different valve spring too. The Cranes are an interesting option if you do not want to change cams but you want increased lift. Go to the Crane web site and read about it for yourself.
08-15-2005, 09:59 PM #9ericegGuest
yeah crane has some nice pieces check out the pics at www.automotivemachine.com they have some of cranes stuff and some other trick stuff
Exploring Rocker-arm Ratio and Cam-phase Tuning - Project Pu
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-08-2012, 08:30 PM -
High-Ratio Rocker Arms - Off Your Rocker
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-19-2011, 02:50 PM -
Roller Rocker Ratio
By WS6ICK in forum Internal EngineReplies: 5Last Post: 09-16-2006, 08:52 AM -
Crane Quick Lift 1.7 ratio Rocker Arm Kit
By Camaro SS in forum Parts For Sale / TradeReplies: 1Last Post: 07-19-2006, 08:29 PM -
Yella Terra LS1 Shaft-Mount Rocker Arms, 1.7 Ratio
By CLHaka in forum Parts For Sale / TradeReplies: 2Last Post: 05-13-2006, 08:00 AM
