Results 1 to 15 of 15
Thread: Can I adjust my Throttle cable?
09-27-2006, 12:03 PM #1Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
I purchased an 01 TB(ported) and have a 99 ws6, I should of done more research before buying but I was too eager. The sprocket that the cable hooks to is bigger on the 01 so my cable is too short right now, it hold the throttle open, is it possible to adjust my cable to where it is a little longer? Or do i need to get a Ported tb for a 99 specific? thanks for any help you can give me.
Wheeler99ws6
09-27-2006, 07:45 PM #2
sent you a pm
08-11-2010, 02:28 PM #3Junior Member
- Jul 2010
- Michigan
Black- 2001 Pontiac Trans Am
Bumping this up since its what I ran into today...
Bought a P&P TB from a buddy who has a 99 T/A
I have a 2000..There is some play in the pedal and the TB cable itself. The P&P already has the bump stop mod to it done. But I had him give me WOT so I can see the blade and its not where its suppose to be.. Since there is some play with the pedal and cable how do I go about adjusting it so its perfect?
WOT seems like 70% for me.
08-11-2010, 06:09 PM #4
08-11-2010, 06:15 PM #5
not sure if you'll ever be able to loosen it enough to make up for the cam sizes on the TB's......please update the thread though if you get it to work as I'm curious.
08-11-2010, 06:23 PM #6Junior Member
- Jul 2010
- Michigan
08-11-2010, 06:34 PM #7Senior Member
- Apr 2008
- Madison, WI
yes essentially thats correct. I think you want to make the cable sleeve longer. That has the effect of making the cable itself tighter/shorter. Confused yet? I could have that backwards but hopefully you will be able to figure it out when its in front of you.
08-11-2010, 08:02 PM #8Junior Member
- Jul 2010
- Michigan
Ok, now do I need someone pressing down the pedal for me to see the blade? Or is this a solo thing.
08-11-2010, 11:39 PM #9
If you have enough adjustment, just loosen until you have a littlle slack with the TB closed, then take up the slack and put the clip back in - should be simple as that.
08-12-2010, 01:10 AM #10BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
TRIPLE BLACK- 2000 CAMARO SS M6 #2100
Just a thought... Can’t you just swap this out with the one from the stock TB? I know that aftermarket TBs come with 2 different sized ones.
Disregard the enormous boobs in the picture, or don’t, since I ran a search for a pic of LS1 TBs on Google and this one came up so I was like, I have to use it!
08-12-2010, 09:50 PM #11BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
I post a pic of large breasts in a TB thread and everyone stops responding.... weird
08-13-2010, 07:00 AM #12
damm that's a nice after market TB. It comes with those included? lol
08-14-2010, 08:17 PM #13Junior Member
- Jul 2010
- Michigan
Adjusted cable by judging off the pic. Thanks! Goes back to bump stop now.
Will have to adjust again. I ported my stock one I took off & looks a hell of lot better.
. Going to decide which one stays/goes.
08-27-2010, 10:31 PM #14VERITAS / AEQUITAS
- Jul 2009
- Ohio (Union county)
Pewter- 2002 T/A WS-6
I took her out for a cruise today, and felt like she just wasnt opening up right. Felt like when I pushed it to the floor it just wasnt fully opening. When I got back to the house I popped the hood and found quite a bit of slack in the cable. (enough that I can pick it up and set it outside of the half circle track its setting in) So I know it needs adjusted, and I head to the computer to see if one of you guys has posted something telling me how and bam I find this thread.
Great easy enough, right.
I run back out to the garage remove my strut towerbrace cause its under the FRC's (so I was thinking) and trace the entire cable to the firewall and its not there. I come back in for a second look and realize the years your discussing has Traction Control. Mine does not, its a 2002 WS-6. I had the TB changed a few months ago but put her up with running her. I'm sure this is what I need to do. Does anyone know if there is another way to adjust this?? Or am I missing something??
08-28-2010, 05:51 PM #15Senior Member
- Apr 2008
- Madison, WI
if there is no adjustment on your cable then you need to replace the cable so it compatible with your TB or change your TB so it compatible with the cable. Or I suppose you could just swap out the TB cam/shaft from your old TB to the new TB.
How do you adjust the throttle 'response'?
By excrider121 in forum Firebird / WS6Replies: 7Last Post: 03-12-2011, 06:13 PM -
Help: How Do I Adjust My Emergency Brake Cable?
By NastySS in forum General HelpReplies: 8Last Post: 03-13-2010, 06:12 AM -
adjust throttle cable
By silver04gto in forum External EngineReplies: 1Last Post: 04-06-2008, 01:29 PM -
The proper way to adjust a throttle valve cable for '93 4L60?
By N20LT4 in forum Automatic TransmissionReplies: 0Last Post: 12-11-2007, 11:20 AM -
Throttle Cable Help
By 90nova in forum General HelpReplies: 3Last Post: 02-09-2006, 01:43 PM
