    NastySS NastySS's Avatar
    West Chester, PA
    2001 Camaro SS 1LE
    How Do I Adjust My Emergency Brake Cable?
    Hello All,
    I have a 2001 Camaro SS, 82,000 Miles, 6-spd Manual, Original Owner, and the emergency brake handle pulls all the way up, then clicks and goes vertical. I looked underneath the car while on a lift, and I could see no adjustments anywhere underneath. Naturally, the cable will stretch a bit over the years. There has to be some way to adjust the tension on the cable, but it is eluding me, and it is aggravating me as I have never seen a non-adjustable cable from underneath. It seems that there is a possiblity that there may to be a way to adjust it inside, but where? I am thinking that there may be a way to adjust it from inside the console compartment, which is right next to the brake handle.
    Any suggestions would be greatly appreciated. Thanks!
    Tom
    My understanding is that it is self adjusting -- you pull it all the way up three times and it is adjusted. There are star wheels at each backing plate that will spread the brake. Might need to take it apart to clean and re-lube everything. Chances are your dust boots are shot, if so let me know as I was able to find them with the assistance of another member.
    West Chester, PA
    2001 Camaro SS 1LE
    Thanks for the response Pajeffo2!!
    Do I pull the handle up 3 times while holding the button at the end of the handle in, or not?
    I don't even know how to get to the brake handle/star wheels or what ever other internals are there. Hopefuly the console does not have to come out. I am very handy though. These dust boots you speak of, if they are at the base of the brake handle, they are in very good shape, I think. I will have to take a closer look. Thanks again.
    Tom
    I believe I held the button in when I did it -- I just installed a new rear axle and had to adjust the parking brake once I had everything hooked back up. The dust boots are at the wheels, on the inside of the backing plate, where the brake cable attaches to the lever.
    West Chester, PA
    2001 Camaro SS 1LE
    Thanks,
    I should have the car on a lift in the next week. I will check the boots then and let you know.
    Tom
    old timer blue02Z's Avatar
    2002 Z28
    it is self adjusts but not that great, you have to adjust it with the star wheels at the rotors. i personally hate pulling the lil plugs i just pull the wheels and the rotors and adjust it with the rotor off then reassemble
    Charlotte NC
    1998 Z28
    Maybe Baby needs a new pair of shoes! I know they are Pads, 86M is time for new brakes. I would check them before they damage the rotors.
    Quote Originally Posted by Civic1 View Post
    I see how this could happen, I just don't think it does.
    If they wear down (which would take a while) you can always just adjust them using the star wheel to spread the pads out a little bit giving better grip.
    Tulsa,OK
    Quick Silver
    2002 Z06
    The owners manual covers the self adjustment procedure. Worked great for me.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
  1. Can I adjust my Throttle cable?
    By Wheeler99WS6 in forum General Help
    Last Post: 08-28-2010, 05:51 PM
  2. Emergency brake?????
    By SandmanWs7 in forum Manual Transmission
    Last Post: 03-16-2010, 07:12 PM
  3. adjust the emergency brake ?
    By NitrOmm in forum General Help
    Last Post: 02-15-2009, 08:18 AM
  4. adjust throttle cable
    By silver04gto in forum External Engine
    Last Post: 04-06-2008, 01:29 PM
  5. The proper way to adjust a throttle valve cable for '93 4L60?
    By N20LT4 in forum Automatic Transmission
    Last Post: 12-11-2007, 11:20 AM
