    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    Emergency brake?????
    I was pulling up on my brake lever and it came waaaayyyyy up> i mean a perfect 90 degree angle and the brakes would not hold. Then i put it down and retried it and it worked. Has done this a few times, has any body had this problem? How did you go about fixing it, or what is the matter with my lever?
    Senior Member
    Jacksonville, FL
    I have an A4 and rarely use mine - but it's happened to me a few times over the years...think it's just one of those things that happens once in a while if you pull it up real fast.
    Member TwistedSS's Avatar
    Irmo, SC
    Quote Originally Posted by 2001NBMZ28 View Post
    Yep...no problems, just let it back down and it should be fine.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    i had it happen from tiem to time when I had a 6-speed. No big deal, it never got worse or anything, just something it does
    Junior Member red99camaross's Avatar
    alberta
    99 camaro ss
    e brake
    that has been happening to me too, does the e brake have an auto adjuster or something?
    There is an adjuster on the e-brake very similar to the star wheel on a drum brake setup. A lot of times, the rubber dust cover over the lever has deteriorated and this allows moisture into the brake assembly.
    I would pull the wheels, unbolt the caliper and caliper bracket and then pull the rotor. You can then check the operation and condition of the parking brake. If it is rusted up, you will need to disassemble it further. I would use the synthetic caliper grease on it in lieu of anything else.
    Here's a pic of what it looks like (before and after pic from when I refurbished mine):
    NeW YoRk
    2001 ws6
    the ebrake is controlled by a cable, that might need adjusting, does the ebrake hold the car still if its on a hill or does it roll?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    The ebrake cable is self adjusting by pulling the lever 3 times. If that doesn't fix your problem then you need to pull the wheels
  1. emergency brake issues
    By 2NDSLPSS in forum General Help
    Last Post: 06-15-2010, 08:33 PM
  2. Emergency brake help needed !!!!!!!
    By 5abivt in forum General Help
    Last Post: 05-08-2009, 11:41 AM
  3. adjust the emergency brake ?
    By NitrOmm in forum General Help
    Last Post: 02-15-2009, 08:18 AM
  4. Emergency Brake Question
    By Archaelas in forum General Help
    Last Post: 02-05-2009, 01:21 PM
  5. Emergency Brake Problem
    By TheJudge05 in forum GTO
    Last Post: 06-10-2008, 02:29 PM
