    Junior Member Archaelas's Avatar
    Marietta, GA
    Triple Black
    1998 Trans Am WS.7 Vert
    Emergency Brake Question
    So, I'm buying my first LS1 (1998 Trans Am Convertible, Triple Black, 6M) and the only real problem I've found with it is the e-brake, handbrake, emergency brake, whatever you wanna call it (silly .co.uk website didn't know what it was... ftw) doesn't grab completely when the car is pointed down hill. If the car is pointed uphill, the car holds nice and steady, no rolling, but pointed downhill, the car rolls forward ever so slowly. I can't figure out why. Anybody have any ideas?
    Ok, so I knew I should have come here first but I didn't. I tried this mechanic's forum http://www.kelsey-forums.co.ukand apparently, the mechanics must be utterly retarded, thinking that this is how the handbrake is *supposed* to work... Unless I'm utterly retarded and am somehow mistaken in thinking that the handbrake on a Trans Am is supposed to work in a different manner than on every other car I've owned.
    Feb 2006
    2002 WS6
    the best chance is that they are worn and need to be adjusted. The reason they work when pointed up hill is because they are designed off a drum brake set up and rotate backwards to adjust.
    all you have to do is remove the rim and rotor, turn the star wheel adjuster to spead them out, and check for draging or binding.
    Marietta, GA
    Triple Black
    Thanks! I'll check that ASAP.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Yeah like he^^^ said their out of adjustment.
    Pretty easy fix, Personally I always leave mine in reverse and pull the Ebrake.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Marietta, GA
    Triple Black
    Same here, I'm pretty good about keeping it in gear when it's parked but just in case I forget, I'd like to have it working. Not to mention, I hate having anything not working right...
    Junior Member chuckstop00's Avatar
    Milford, MA
    2000 Firebird Formula
    Another little trick to "extend" the life of the emergency/park brake, is to
    make sure there isn't a "lip" on the inside of the rotor, which acts as a drum.
    If there is, it will limit how far out you can adjust the shoes, without being
    able to put the drum (rotor) back on. I took a half-round file and smoothed
    off the lip, then was able to adjust the shoes out slightly more. Bottom line
    is once it gets worn (rotor/shoes) need to get new stuff. Also, I don't think
    you can access the star wheel without taking the rotor off, would be nice if
    you could.
    Orlando FL
    Red+White Top and Stripes
    2000TransAmConvertible A4
    Welcome to the site.
    Marietta, GA
    Triple Black
    Quote Originally Posted by chuckstop00 View Post
    you could.
    Great advice, thanks! I'll check it out asap.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    you could.
    Is there a rubber plug in the backing plate that comes out so you can access the star? This is what drums have to adjust them. What about going in reverse and pulling on the ebrake? Does this adjust them like in a drum car?
  1. emergency brake issues
    By 2NDSLPSS in forum General Help
    Last Post: 06-15-2010, 08:33 PM
  2. Emergency brake?????
    By SandmanWs7 in forum Manual Transmission
    Last Post: 03-16-2010, 07:12 PM
  3. Emergency brake help needed !!!!!!!
    By 5abivt in forum General Help
    Last Post: 05-08-2009, 11:41 AM
  4. adjust the emergency brake ?
    By NitrOmm in forum General Help
    Last Post: 02-15-2009, 08:18 AM
  5. emergency brake question when running C5 rotor
    Last Post: 07-22-2007, 07:04 AM
